BX25D / B2601 Time to switch between MMM to BH w/ subframe
   / BX25D / B2601 Time to switch between MMM to BH w/ subframe #1
JFoy
Clemmons/Lexington, NC
Kubota BX25D
So, I'm talking to my dealer about buying either a BX25D or B2601. From what I gather, you cannot raise or lower the MMM if the BH subframe is in place. They recommend having either the MMM or BH+subframe, but not both at the same time. Now, switching this subframe in and out sounds like a major PIA. Anyone with experience in this care to comment on time and effort to switch back and forth?
Thanks
   / BX25D / B2601 Time to switch between MMM to BH w/ subframe #2
You need to find a new dealer he doesn't know what he's talking about. I have mowed more than once with my BH on, as long as the 3-point hitch is off it's no issue...don't think you could get the BH on with the 3-point hitch without damaging one or the other anyway.
sea2summit: Sent you a PM. Thanks
   / BX25D / B2601 Time to switch between MMM to BH w/ subframe #4
I have mowed with my Bx25 and backhoe on, the subframe on the 25 is part of the frame, it doesnt come off. Dont know about the B2601?
Slimshadie: Are you able to raise and lower the deck of the MMM while the subframe is in place? In my situation, I have to cross some uneven areas with rocks so I raise the deck of my lawn mower when crossing those sections.
   / BX25D / B2601 Time to switch between MMM to BH w/ subframe #6
There is no change to the operation of the MMM with the BH on. Raise/lower/instal/remove it doesn't change when the BH is on.
   / BX25D / B2601 Time to switch between MMM to BH w/ subframe #7
As Sea2 said, its like the BH is not even on. Now its not the greatest ride for sure with everything on, FEL & BH while mowing. Way better with everything off and your not so long too. There really isn't a subframe on the BX25. The subframe and frame is 1 unit.
   / BX25D / B2601 Time to switch between MMM to BH w/ subframe #8
If the 2601 is set up like the Bxx20/2650/3200. then NO you can not raise and lower the mmm with backhoe in place.
The 3pt hitch is used to raise and lower the mmm on the 3 B's I have owned.
The BX25 was able to raise and lower the mmm with backhoe in place.
   / BX25D / B2601 Time to switch between MMM to BH w/ subframe #9
On my L3240 taking the backhoe off is easy maybe a 3 minute job. Putting the 3 point arms back on would take another 5 minutes. Removing the subframe is a huge job. It took me 2 days to put it on.
Thanks to everyone for the replies. Lot of features in the B2601 I liked but the whole subframe vs. MMM was a deal breaker for me. I opted for and bought a BX25DLB today.
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
Heaven Hill Bourbon Barrel (A57454)
Heaven Hill...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
Spatco Air Compressor (A57454)
Spatco Air...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56436)
LMC 2-Row Planter...
