Buying Advice In search of a sub-compact tractor
/ In search of a sub-compact tractor #1
Milton, ON
B2650
Hello everyone,
This is going to be a bit longer than I think I would have intended. I have posted a short version if you cannot go in depth, but I value your opinion, as I am certainly a novice.
Short version:
I am looking for sub-compact tractor, valuing long-term reliability/repairability and versatility for small jobs around a 20 acre cottage property that has not had any "outdoor" (or indoor :()maintenance in my adult life. I feel as though I need something that can lift more than 1 30-year old man and 1 60-year old man. What I would REALLY like, would be to have someone say Subcompact Kubota vs Deere Vs MF vs NH vs etc. for various tasks, like a consumer reports, but I cannot find one. While it seems like there are a lot of 1v1, there is not much 1v1v1v1v1v1 that I can find.
Longer version;
I would have really liked to have found my topic in the various threads here as there seem to be a lot of knowledgeable people here. While they are all very helpful, I do not think they provide sufficient details for me to make a decision (and maybe even after I ask this question, I might just end up with the first Dealer I went to - unfortunately?). Before I jump in to this, I would like to know about experiences of people using their sub- or compact tractors to do the kind of activities I need. I.e. is it going to just add a machine that takes the same amount of time and makes me lazy, just a waste of money, etc.?
So the story. I live in Canada and my parents have a long 3 season cottage on about 20 acres, most of which are untouched mixed forest, not much brush and there is some grass. About 2-3 acres are grass and due to the shape of the land it takes 2 people about 2 hours to cut the grass once a week using a couple Craftsman lawntractors.
Foreseeable Frequent Tasks:
A list of the projects that we may end up doing in order of frequency/likelyhood are below:
1. Mowing (I have read a few threads here that say you probably shouldn't mow with a TLB, but right now we use a 30 and 15 year old craftsman in tandem)
2. Forking pallet-like objects - actually 80lb 2'x6'x2" trex dock boards
3. Towing a trailer (full of stuff, eg. trees, stumps, logs, dirt, cleared brush, etc. eg. when the lawntractor is replaced)
4. Removing trees/clearing brush
5. Landscaping (reshaping land, moving rocks, logs)
6. Replacing a couple culverts
Less likely, but possible:
-Maybe snowblowing in the future?
-Digging an outhouse
-Clearing a driveway
-Digging a septic tank
-Building a garage
-Building a cottage
I do not want to say cost is no object, but I would rather pay 10% more for a more reliable brand. At this time I do not think I will buy used, as this will be my first tractor and no dealers are near. Additionally, I feel as though the market for used tractors in my area of Canada in this size is limited. I am also constrained in terms of size, as I do not have somewhere to store a large tractor; it must be a compact or sub-compact. I went to the closest tractor dealer to my house (none are really "near" my cottage in Huntsville, Ontario which would sway it as well) which happens to be a John Deere place. The guy was helpful, I got some brochures (their site is horrible IMO), and a quote. I think that I would probably be alright with the 1025 from John Deere. In CAD it's ~$31,000, which seems on par with what I was expecting.
/ In search of a sub-compact tractor #2
I take it you didn't realize there is a Kubota factory in Orillia ?
Get something that is 4 wheel drive with a diesel powered 3 cylinder engine, hydrostatic drive makes it easier to operate and a little harder to break, a front loader is one of the most useful attachments you can put on it, but limited to how much serious digging you can do unless you beef them up a bit. The quick detach front loaders are actually a bit of a weak spot, because the loader arms bolt to either side of the transmission bell housing and lack cross-bracing that the heavier duty loaders have. Add a box scraper landscape blade for the rear they are great implements, very useful for grading, cultivating, snow removal on gravel drives and contribute to stability by adding weight very low on the tractors 3-point hitch, which is the strongest part of a little tractor. If you are going to use it to mow, consider one that has a centre PTO drive as well as the one on the rear. I bought a 72" wide rear discharge finishing mower, that works great for mowing large areas of grass in a hurry, but the tractor is too heavy with industrial tires that are loaded to mow a tile bed, so you still need a small mower for tight spots (buy a small zero turn and a push mower for everything the tractor can't do) If you buy a blower it will likely drive off the centre PTO, make sure your blower and front loader are the same width as the overall width of the tractor, don't go undersize on those items. Expect to keep it in a heated environment or to need to heat it up often to use it in the winter. Winter is brutal on the hydraulic oil because of frost condensation that will form inside the transmission and pollute the hydraulic oil with water. Once water forms in the oil that will turn to ice inside your oil filters and when that happens the tractor will not go. Expect to change oil and oil filters frequently to prevent this problem from escalating.
Fuel filters are tiny and also suffer from ice problems, replace those frequently and keep your fuel tank full in cold weather to prevent condensation buildup. Buy diesel fuel conditioner and add a small amount of it to the tank frequently, that will keep your injectors in good shape and possibly help to combat water in the fuel issues. Keep the battery charged and buy a magnetic block heater to stick on the oil pan. Don't run it out of fuel and if you do, you are going to need to figure out how to bleed a diesel's fuel system. 26 horsepower or as close as you can get to that in a Kubota is a nice size, I think Kubota's on average have slightly less H.P. then the New Holland equivalent.
Good luck finding a lightly used one, but if you can't find an almost new one buy a new one, you won't lose much money on it if you take good care of it, tractors hold their value well, as you may have noticed in trying to find a used one cheap. They are a ton of fun to operate and extremely useful to have on a hobby farm :thumbsup: Get one.
Thanks for the amazing reply. I will have to read it couple times to digest, particularly about the cold weather operation. How do they handle being turned off in the fall and turned on in the spring? Is the Kubota factory the one off of highway 11, Kubota Materials factory?
Man, I just read it again, what an amazing reply
/ In search of a sub-compact tractor #4
:D No problem if you don't use it through the winter months, it's the repeated cycles of hot and cold that cause the most grief with condensation. Just do your oil changes in the spring, drain a small amount of oil at the end of the season, if the oil looks cloudy, or milky like, then that is water mixed with the oil. Yes to the Kubota factory, I believe they make a lot of metal parts there including tractor engine components.
/ In search of a sub-compact tractor #5
I think a SCUT is too small for your property.
/ In search of a sub-compact tractor #6
I would buy a mower that could cut the grass in two hours with one person. I would buy a medium sized compact tractor 30 to 45 hp. for the rest of the work.
Thanks for the advice both of you. Could you elaborate on the things that a sub-compact tractor would struggle with?
/ In search of a sub-compact tractor #8
Ground clearance. Weight & traction (weight = traction). Loader breakout force (digging out rocks and boulders).
/ In search of a sub-compact tractor #9
Ya, I'd like to hear about that, and in the meantime let me show you a little of the landscaping I've done with my little SCUT, before I even bought the backhoe attachment ;) this was all level ground before I started, I have 3 properties with a total af just under 400 acres. My TC26DA is the biggest tractor I can transport in my dump trailer and legally tow it behind my truck. I traded in a larger tractor for the one I have now.
btw: don't buy a backhoe, for the small amount of use you will get out one, rent it from me :D
add: many of those rocks are upwards of 600 pounds.
Thanks for your input so far:
So would something like an L3301HST, JD3032E, MF1734E be what I should be looking for? Without having shopped, I suspect they will be say 10,000 more without a mower deck and I don't think I would be able to mow with them (not that it's necessarily a terrible thing)
One thing I noticed is that it does not seem as though Deere has a finger on their backhoe, is that an uncommon, not very well used feature, or did I miss it?
/ In search of a sub-compact tractor #11
Given your list of tasks and land size:
- 25-40 HP
- Deere & Kubota are close by (parts/service/resale) not sure how near Kioti, Massey, and NH are?
- Get a QA skid steer type removable bucket quick attach and forks, grapple, and front blade for snow
- Additional remote hyd valves for grapple on front and two on rear for rear blade tilt etc.
- a backhoe with a thumb definitely if you want to be more self reliant for the ditches and trenching and foundation (rather than renting)
- instead of a Mid mower ($1800) get a dedicated better mower
- Build or make a secure storage shed (10x20) or so for your new tractor with enough door clearance 8' with electrical if possible to work on or plug in block heater to warm up the engine
Attachments like a rear blade, and snow blower can be bought later used for half or less, but if you want to get all new at one time you probably can get a better deal buying all at once.
Good Luck!
/ In search of a sub-compact tractor #12
L3301HST in 4 wheel drive looks pretty sweet to me! That tractor without any attachments is going to be the heaviest tractor you will be able to tow without an upgraded truck license, if that is of any concern. It is at least one step up in size from the one I now have and much closer to the Ford 1900 that I previously owned.
The backhoe added to a little tractor is fairly limited, a finger is not going to do all that much for you. Working a backhoe hard on a tractor like these can be hard on the tractor if you over-tax it. They are great for trenching and that is about it. If you need to move serious amounts of material or pluck trees out of the ground and pick them up you are going to need a serious excavator :D like the one I just bought last week:
it has a finger, plus a 27 foot reach with 19 tons of lift.
/ In search of a sub-compact tractor #13
MTS, my situation is similar to yours. I live in Toronto and my cottage is near Dorset, and on 25 acres with an acre or so of grass. I bought a Kubota BX 25 from Kubota North in Bracebridge, and I like them a lot. I got mine for $18,000, and it includes a backhoe, but if you're going to spend about $30,000, you can get a B 2650 with a backhoe for that, easily. (Don't forget, the Kabota dealers do nice discounts from MSRP.) Go on to the kubota.ca website, and do a comparison of the BX 25 and the B 2650, in order to help you make your decision.
Wow, I wish I were in your position, in which case I would definitely buy the B 2650. Heck I would even go shopping with you!
/ In search of a sub-compact tractor #14
:thumbsup: we like spending other peoples money.
Jesus what a machine. I would only be able to use that in the winter when the ground is frozen, or mid-summer during a dryspell or it would destroy everything!
I shall give Kubota north a call, I'm nowhere near them right now but you know - maybe I can be convinced. As far as price and spending money, I'm not rich, but I have no need to get something that will definitely be too small as I already have enough "struggle" to go around. From what it sounds like, I should be looking for something on the slightly larger end. Also it sounds like the Deere is kind expensive relatively speaking. How long ago did you buy yours Check?
/ In search of a sub-compact tractor #16
Given the tasks you list, and the fact that you say you want a SCUT, it is difficult to make a recommendation. This is because many of the items below could be done with a SCUT if the scale is small, but would require something larger if the scale is larger. Removing trees (with stumps? size of trees?), towing trailer (weight of trailer? terrain being towed on?), Moving rocks / logs (size / weight for both?), replacing culverts (size / weight of culverts?). A SCUT will do everything below as long as the scale is appropriate for an SCUT. If you expect to pop 4,000 pound rocks out of the ground, you will be disappointed with an SCUT.
-Building a garage
-Building a cottage
/ In search of a sub-compact tractor #17
I am essentially struggling with a similar question. I have uses that could easily span from a BX (sub compact), to a B 2650 (26HP) to an L series with much more HP and weight. I have pretty much ruled out the BX...mostly because I am confident I would try to use it for tasks it is not designed for and likely bend or break parts. :)
In my review I seem to cycle back to the B 2650 as a much sturdier unit than a BX BUT not as heavy and large as the L series. I also would like to consider the extra HP of the B 3350 but am not confident the Tier IV pollution equipment is working correctly yet and "most" seem to advise no getting the B 3350 unless you REALLY want/need the extra HP.
My probable course will find me getting a B 2650 w/MMM(maybe), loader, box blade, brush hog and eventually a grapple. Still may decide to skip the MMM and go with a regular lawn tractor to avoid taking on and off frequently.
I have narrowed my choice to Kubota as I trust their history and also they have been the leaders in developing much of the sub-compact and compact market.
FWIW...Tom R
/ In search of a sub-compact tractor #18
Buying the right machine can be difficult without a lot of experience using various sizes. Not knowing your long term needs in detail makes it difficult to make good recommendations with real meaning. We all have budgets to deal with in the real world and often buy too small trying to save money. Sometimes you have to balance budget constraints with the long term goals and have a meeting of the minds. I have found that a long term plan for a property such as you have listing the improvements in detail should lead you to the correct equipment to accomplish your goal.
Time is another important consideration, some jobs you may be able to chip away at here and there. Sometimes you need to get it done before a rain makes a mess out of everything.
Trading up in size later can cost you a lot more money than buying the right machine the first time. Buying to big and not being able to fit in the work space can be another problem. You want to pick the machine that will handle 90% of the jobs you have for it to do.
Mowing versus dirt moving, tree removal and other tasks in my opinion require separate machines. Pick the best mower for your landscape and get a tractor to do the other heavy jobs. Mowers should be light in weight, tractors need to be heavy, two different machines.
All of that said above, if you can pin down what you would like to do in detail with a lot of thought in it you will have a much better idea of what you need.
/ In search of a sub-compact tractor #19
For the cost of the MMM you can put a serious down payment on a zero turn mower. That will do a much better job at mowing.
If you do not need to detach the bucket the NH has much better lift capacity than the deer. Also cheaper. At least down here.
/ In search of a sub-compact tractor #20
Greetings Northtractor,
I'll take a little different direction than others if you don't mind.
You have a wish list and that's fine. But you also have two craftsman lawnmowers . . so that's an experience level I'll work from.
To keep it short for now and then expand on it later, I sense you ate not in close proximity to lots of business related repair locations and service centers.
So I would 1st focus on reliability.
To that end I'd narrow the grouping to equipment that is designed and engineered by long time engine builders who expanded to full tractor building over many years:
Yanmar, Kubota, or Iseki (Massey).
New Holland, LS, Mahindra, Kioti etc. All may have some fine product . . but when reliability and long warranties and good manufacturer insurance policies are important I'd stick with the 3 I listed.
I also didn't list John Deere . . unless their product is built and designed by 1 of the 3 I listed.
Back later for more reasons why.
And at this point . . don't get too swayed as to scut or cut in my opinion.
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
2025 AGT Industrial MX-MRW14 (A60463)
2025 AGT...
2008 INTERNATIONAL DURASTAR 4400 CAB AND CHASSIS (INOPERABLE) (A60736)
2008 INTERNATIONAL...
SD Lanch SDLG80 Electric Golf Cart (A60463)
SD Lanch SDLG80...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
