Max 28XL 3rd Function Kit
/ Max 28XL 3rd Function Kit #1
200TrueBlue
Member
NL
Max 28 XL
Hi
Has anyone installed one of these kits from Brian at Fit Rite Hydraulics ? I would like to see pics how and where
You installed the valve and how your hoses are tied in and routed on a Max28 XL unit.
Thanks
Bill
Valve kits
/ Max 28XL 3rd Function Kit #2
Hi
Thanks
Bill
Valve kits
Bill, is there room to do this similar to how I did my 3215?
valves-photos
I think we may need to do some alterations with the joystick also.
Brian
Would I use 1 cylinder or 2 for angle on my plow with this setup?
Bill
/ Max 28XL 3rd Function Kit #4
Brian
Bill
Bill, sort of depends on how things are set up. I think that most snow plows have 2 separate cylinders. Probably less thinking involved and stronger. But it can be designed and built so that a single unit would work. As far as the 3rd function, it will work with either 1 or 2 cylinders. That won't matter. ;)
2015 Volkswagen Passat Sedan. (A61569)
2015 Volkswagen...
2025 X39 Hydraulic Trencher Skid Steer Attachment (A61567)
2025 X39 Hydraulic...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
UNUSED TAYLOR-WAY 5' BOX BLAD (A62130)
UNUSED TAYLOR-WAY...
2014 Mercedes-Benz C250 Sedan (A61569)
2014 Mercedes-Benz...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
