Max 28XL 3rd Function Kit
/ Max 28XL 3rd Function Kit #1
200TrueBlue
Member
NL
Max 28 XL
Hi
Has anyone installed one of these kits from Brian at Fit Rite Hydraulics ? I would like to see pics how and where
You installed the valve and how your hoses are tied in and routed on a Max28 XL unit.
Thanks
Bill
Valve kits
/ Max 28XL 3rd Function Kit #2
Hi
Thanks
Bill
Valve kits
Bill, is there room to do this similar to how I did my 3215?
valves-photos
I think we may need to do some alterations with the joystick also.
Brian
Would I use 1 cylinder or 2 for angle on my plow with this setup?
Bill
/ Max 28XL 3rd Function Kit #4
Brian
Bill
Bill, sort of depends on how things are set up. I think that most snow plows have 2 separate cylinders. Probably less thinking involved and stronger. But it can be designed and built so that a single unit would work. As far as the 3rd function, it will work with either 1 or 2 cylinders. That won't matter. ;)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused 3 Point Ball/Flat Hitch (A61166)
New/Unused 3 Point...
New/Unused Wolverine Quick Attach Auger (A61166)
New/Unused...
MASSEY FERGUSON 255 TRACTOR (A62130)
MASSEY FERGUSON...
2010 Deere 318D (A60462)
2010 Deere 318D...
2025 SDLANCH SDLC2030FT All-Steel Carport with Sidewalls (A60352)
2025 SDLANCH...
