How do I know if I have a HSTC-3?
/ How do I know if I have a HSTC-3? #1
C4Ranch
Eastland Co, Texas
Kubota L5240 HSTC
Anyone know how to tell the differences of hst vs hst-3?
TIA!
/ How do I know if I have a HSTC-3? #2
One difference is;the HST use a lever for PTO engagement ,the HST-3 uses a pull-up button.I am sure there are other differences also.
None of the above, so must be a 1 or 2..
Thx
/ How do I know if I have a HSTC-3? #6
Yep the stock seat on an L40 HST-3 swivels. There is a pedal right in the front you pull up on and swivel until it clicks and locks in place.
/ How do I know if I have a HSTC-3? #7
The C means Cab. That part should be obvious... Not sure what they added later on with the 2-speed HST motor or the auto throttle stuff. Maybe that was there from the beginning.
/ How do I know if I have a HSTC-3? #8
My older M9 is an HDCC3 which denotes Hydraulic Shuttle Cab Creep gears which adds 3 ranges to the gearbox. Note, the 2 speed pto (540 / 1000) has no model letter designation.
My seat swivels as well and it's air ride too.
That's exactly what I don't understand. Does the 3 mean 3 ranges? I have cab, lever PTO, auto throttle advance, turtle/rabbit speeds....
Woods says they have a subframe but it's for HSTC-3
/ How do I know if I have a HSTC-3? #10
TIA!
Does your tractor have at serial number sticker on dash? My M7040 does and it shows my tractor is a HDC-1 so your model might be listed on sticker if it has one.
YANMAR VIO35-6A EXCAVATOR (A59823)
YANMAR VIO35-6A...
1993 Baja 29ft. Boat w Tri-Axle Boat Trailer. (A59231)
1993 Baja 29ft...
2007 FORD EXPLORER (A60736)
2007 FORD EXPLORER...
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59231)
iDrive TDS-2010H...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
