90degree fitting question
/ 90degree fitting question #1
Jeff59Va
Member
Centreville, VA
Kubota L3240HST, Kubota RTV1120D, Kubota BX2380
Getting ready to finalize and order for some hoses and fittings, but my plan hinges on 2 of the 90 degree fittings being oriented a certain way. So for this fitting: 6801-06-06 | 3/8" JIC Male x #6 SAE/ORB Male 90° can the JIC side be oriented any way you want when you tighten down the ORB side? The ORB end is going into a diverter block, so the JIC end needs to point away from the mounting plate that the block mounts to.
Thanks!
/ 90degree fitting question #3
Getting ready to finalize and order for some hoses and fittings, but my plan hinges on 2 of the 90 degree fittings being oriented a certain way. So for this fitting: 6801-06-06 | 3/8" JIC Male x #6 SAE/ORB Male 90ー can the JIC side be oriented any way you want when you tighten down the ORB side? The ORB end is going into a diverter block, so the JIC end needs to point away from the mounting plate that the block mounts to.
Thanks!
You have a diverter that takes a #6 ORB fitting? Everything that I have seen takes #8 fittings. Please let us know about this, it sure would make plumbing these much easier. :cool: Or is this just the sub-plate for an electric valve, not actually a diverter valve? :confused:
Screw the ORB fitting in a few turns, orient it where you need it, and lock down the jam nut.
Great - I was hoping that was the case.
It's the one that Ken sells: Ken's Bolt on Grab Hooks <<Hydraulics>>
Maybe I have the terminology wrong?
/ 90degree fitting question #6
/ 90degree fitting question #7
I have all the parts I stock to turn the ports 90* and convert them to -06 JIC, just haven't got a picture yet to get them posted on the website as a "kit".
Give me a call Jeff if you want some.
/ 90degree fitting question #11
Tough crowd on TBN these days :)
iDrive TDS-2010H...
2005 Toro Z Master Commercial 72in Zero Turn Mower (A61572)
2005 Toro Z Master...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63688)
2017 Cadillac...
213154 (A64276)
213154 (A64276)
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2007 Montone AD24465448 30ft. Tri-Axle Aluminum End Dump Trailer (A61573)
2007 Montone...
