90degree fitting question
/ 90degree fitting question #1
Jeff59Va
Member
Centreville, VA
Kubota L3240HST, Kubota RTV1120D, Kubota BX2380
Getting ready to finalize and order for some hoses and fittings, but my plan hinges on 2 of the 90 degree fittings being oriented a certain way. So for this fitting: 6801-06-06 | 3/8" JIC Male x #6 SAE/ORB Male 90° can the JIC side be oriented any way you want when you tighten down the ORB side? The ORB end is going into a diverter block, so the JIC end needs to point away from the mounting plate that the block mounts to.
Thanks!
/ 90degree fitting question #3
Getting ready to finalize and order for some hoses and fittings, but my plan hinges on 2 of the 90 degree fittings being oriented a certain way. So for this fitting: 6801-06-06 | 3/8" JIC Male x #6 SAE/ORB Male 90ー can the JIC side be oriented any way you want when you tighten down the ORB side? The ORB end is going into a diverter block, so the JIC end needs to point away from the mounting plate that the block mounts to.
Thanks!
You have a diverter that takes a #6 ORB fitting? Everything that I have seen takes #8 fittings. Please let us know about this, it sure would make plumbing these much easier. :cool: Or is this just the sub-plate for an electric valve, not actually a diverter valve? :confused:
Screw the ORB fitting in a few turns, orient it where you need it, and lock down the jam nut.
Great - I was hoping that was the case.
It's the one that Ken sells: Ken's Bolt on Grab Hooks <<Hydraulics>>
Maybe I have the terminology wrong?
/ 90degree fitting question #6
/ 90degree fitting question #7
I have all the parts I stock to turn the ports 90* and convert them to -06 JIC, just haven't got a picture yet to get them posted on the website as a "kit".
Give me a call Jeff if you want some.
/ 90degree fitting question #11
Tough crowd on TBN these days :)
2023 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2023 Peterbilt 567...
2018 Ford F250 4x4 Ext. Cab Pickup Truck (A64194)
2018 Ford F250 4x4...
2019 KAUFMAN 46' STEP DECK TRAILER (A64280)
2019 KAUFMAN 46'...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A64279)
2021 CATERPILLAR...
(4) BOTTOM TURN PLOW (A64280)
(4) BOTTOM TURN...
(2) ROOKIE SHEET RACKS W/WHEELS (A64281)
(2) ROOKIE SHEET...
