FEL seems weak- how to check
/ FEL seems weak- how to check #41
That is a perfect shot, showing how my JD 4910 loader bucket was attached to the bucket and allowed for me to bend the cyinder's rods when I put the bucket vertical and did the "back drag" movement with the wheels off the ground.......slightly.
Yep, I have done a lot of back dragging with the bucket vertical, but with the loader in float. If the front wheels are off the ground the bucket ain't moving. :D
/ FEL seems weak- how to check #42
I have also slightly bent loader cylinders doing that. I had a tooth bar on which added more leverage. If you have the loader in float it probably won't hurt anything, but a regular tractor can lift the front wheels off the ground and backdrag.
/ FEL seems weak- how to check #43
Since this thread is so far off topic, I will show how I do some serious "back dragging", with down pressure if needed.
A year later. :thumbsup:
/ FEL seems weak- how to check #44
I don't think we are veering too far. The thread is about hydraulics and FELS. That's what we are talking about.
Your invention deserves credit. Well done. Makes a lot of sense. I was cleaning out a pool bank when I bent my rods. That idea of yours would do a mean job of bank cleanup. Will keep it in mind next time we have another drought. Seem to be the norm now adays. This year we had 30ish inches of rain in the spring keeping the ground unusable till June when you usually plant the warm season crop end of March. Then 4 months of no rain. Now another monsoon. Got 13 inches in 3 days on top of 10 inches over the month before. Farmer's Almanac said it would be a wet fall. How they know a year ahead of time and be right more times than wrong beats me. All this following 4 years of serious drought. Good time to clean things out.
/ FEL seems weak- how to check #45
Mark
I hope it's several yrs before it gets dry enough in our neck of the woods for you to be able to clean your stock pond out!!
Jim
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
3pt 2 Row Bedder (A64119)
3pt 2 Row Bedder...
UNUSED INDUSTRIAS AMERICA 190-9' SCRAPE BLADE (A64280)
UNUSED INDUSTRIAS...
2022 EZ-GO ELITE...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
Engine (A59228)
Engine (A59228)
