Has anybody built a box blade?
/ Has anybody built a box blade? #41
What are the typical side wall dimensions, and what's the best angle for the bottom edge relative to the back?
I've been wanting to build one for a while, but without a design template, I've been reluctant to start sourcing materials.
/ Has anybody built a box blade? #42
I'd go to your local road maintenance shop for cutting edges, whether that's city or county, not knowing where you live. For scarifier teeth I'd go to your local tractor supply store or it's equivalent. I drew a set of plans for a BB but just never energized the plan. I thought it would be a fun project, regardless of cost. And you are correct, you can build a Bad A** BB for what it would cost to buy a cheap one. Don't forget to post pics if you do it!!!! :)
Was that a CAD drawing you did? If it was any chance you could let me take a look at the file??
/ Has anybody built a box blade? #43
No way I'm that Hi-Tech..... It was a Power Point drawing. For some reason I can't attach it here???
/ Has anybody built a box blade? #45
Take a screen shot and post that pic. ;)
Just figured out the problem. My shop computer doesn't have Office/Powerpoint. I'll take the flash drive into the house this evening and get a picture using the house computer and then post tomorrow.
/ Has anybody built a box blade? #46
The side wall is 3/8 on my Cammond.
Here is the only drawing that I found with a Google image search. It is a low back style.
/ Has anybody built a box blade? #47
I'm more interested in the front to back and top to bottom lengths, and what the included angle of the bottom right corner in the right picture is.
The land pride dimensions are helpful though!
2003 Keystone Cougar Model 286 Camper / 5th Wheel (A66285)
2003 Keystone...
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2024 JCB 35Z-1 EXCAVATOR (A65053)
2024 JCB 35Z-1...
2015 Mack CXU613 Tri-Axle Day Cab Truck Tractor (A64194)
2015 Mack CXU613...
2019 Dodge Charger Sedan (A64557)
2019 Dodge Charger...
Metal Sunflower Spinner (A65583)
Metal Sunflower...
