When to have underground utilities marked?
/ When to have underground utilities marked? #21
Back in the 70's I was building a sub division in Southern California. That was in the day when the current dig alert system did not exist. We were running utilities in an old dirt road, but we knew utilities existed in the right of way. I called each of the local utilities to locate and sure enough the phone company had a line in the road. They marked it out and we potholed it to determine it's depth before the contractor arrived. It was buried only about 12".
When the pipeline contractor arrived the first day, I took their foreman to the pothole location and showed him the telco line. Warned him that this was a DIRECT BURIAL MAIN TRUNK LINE between San Diego and LA. The line was about 3 1/2 in diameter. That day, the foreman left the site for something and forgot to tell the operator about the line. Yeah, they trenched right through it.
Telco came in and set up a pair of portable microwave towers on both sides of the break and spliced the 900 lines into each. It took several days at 24 hours per day. They required the contractor to install a large underground splicing vault at the break location. After several weeks of replacing in the vault the line was restored.
The Telco charged the contractor for all work to restore plus line charges for every minute of loss revenue of each line broken until the service was restored.
The final cost to the contractor was over $500,000!:eek: ...and to boot, the contractor was self insured. Fortunately they were large enough to suffer the loss and continue in business.
/ When to have underground utilities marked? #22
If it's marked wrong it's on the locator doing the marking.
In most places it's 2 ft on each side of paint mark (4 ft total) and whatever the depth the utility is does not matter. The locator is not required to give a depth so if it's marked and under a leaf and you hit it. It is on you.
It's the same here for the provincial utility's buried electrical lines. Back when I first started in district work part of my duties was locating lines and the equipment we used had no provision for depth. The newer locators have a depth provision but without daylighting the cable it's impossible to verify what they give as a measurement so we never would give a depth. Besides that, tell them it's two feet deep and many of them will try to dig 23 inches deep. Some would ask how deep the lines were and the only thing we would tell them is what it was supposed to be when installed but from experience, many times the grade was changed after the cables was buried.
/ When to have underground utilities marked? #23
Yep , We ran power for lot lights , with 2 ft of cover a few weeks ago . Then started coring the parking lot and driveway . Not a good layout by the engineer . Saw the top of the conduit more than once .
/ When to have underground utilities marked? #24
The 811 guys love me. We drill dynamite shot holes for seismic exploration. The holes are 10-20' deep typically and a typical job may be 4000 acres with over a thousand holes spaced all across it. Since we are using explosives not only do we have to worry about drilling into a line but there are certain distances the holes must be from various underground utilities. Last job I had them mark it took them three weeks to mark all the lines.
For your scenario I would always make the call. It is the law that you do. You have to call at least 48 hours before work begins and then you have a limited amount of time to do the work or it has to be remarked.
As a general rule things that are really dangerous like gas or electric lines are deep but not always. At my place the electric service line to the house is six feet deep. We have a gas pipe line running across our field in the back and I chisel plow that field all the time about a foot deep. Things like cable and phone lines are often very shallow.
/ When to have underground utilities marked? #25
I am not sure of the details but there are some times you do not have to call. I farm several fields along roads and from what I have been told I do not need to call for my agricultural land. My nephew has twice caught telephone cable which then needed to be replaced at no cost to him. When the power company was running a power line under one of my fields to my new neighbor's place, I asked the question. The crew told me that in agricultural land they needed to be buried at least 18 inches, but usually are around 24".
/ When to have underground utilities marked? #26
I install irrigation systems , I hit a fiber cable that was mismarked and it was an inch in the ground . I always take pics of the site before I dig to verify where the marks were . The locaters are quick to spray lines after a problem to cover their butts
Why, or how, do you bury a cable 1" deep?
/ When to have underground utilities marked? #27
Sounds strange for a "real" cable, but I've seen telephone drops buried barely under the roots of the grass. The reason? To avoid cutting previously placed drops that were 1" deep, that were placed that shallow to avoid cutting those already there that were 2" deep.
/ When to have underground utilities marked? #28
When I was a commercial superintendent, the cable/data company hired by the building owner literally lifted fresh sod to lay the drop and the set the sod back down. Shovel or trenches never hit the ground.
/ When to have underground utilities marked? #29
Well, a big thing with that is that buried electric should be in an easement or ROW, they can't just put it across someone's private property.
Agricultural land often has exemptions, but I would always call. It's free, and covers your butt.
As a point, most 'transmission' gas isn't placed it the road right of way, and often crosses pastures. There should be markers of coarse, but they can get knocked out from animals and or ag work. Even a small 6" steel high pressure gas line will be bad news. They should in theory be at least 36" deep, but with 20+ years of erosion, cut/fill, and other stuff, that 36" could easily turn into 12".
Edit; gas pipe lines are often patrolled from air, and they are places in plotted, recorded right of ways and or easementw, bit you can't always see from in the field
/ When to have underground utilities marked? #30
I called ' Miss Dig ' as soon as I procured my backhoe. I knew where everything was except the phone line out thru the woods. Does not cost anything, and worth it for peace of mind.
/ When to have underground utilities marked? #31
Even in agricultural work don't take anyone's word for it that the dig is clear. I was digging on a ranch in a pasture a few years ago and had believed the farmer who had lived there for forty years and said there was nothing in my path. Well I dug a trench for a new irrigation line and about 300' down the inside of the fence spotted a phone box almost covered in the weeds. I stopped and called 811 and waited for them to mark. Glad I did because there was a 600 pair phone line about 10' ahead of my line. That line was put there about 50 years ago and was still in use. That would have cost me dearly. So I learned a cheap lesson, don't trust anyone.
/ When to have underground utilities marked? #32
I was the spotter/all round joe boy for a trencher in Alberta many years ago. We were trenching for irrigation on a farmers field. The operator told me to sit in his pickup truck where the crossing lines were flagged. It was my job to hand dig where the flags were when he got close to them. Everything was going great until he hit a line that wasn't marked. The line was empty/unused but he still came out of the cab a lot faster than he ever got into it. We trenched a lot slower after that. Lesson learned. Do NOT trust anybody.
Call before you dig is there for a reason. The life you save may just be your own.
/ When to have underground utilities marked? #33
Cable tv installers do it a lot, i watched them do it in my yard. They use a garden spade to make a "trench" about an inch deep, put the cable in and walk on it to close/compact it. I told him at the start that wasn't deep enough. He put my name on a list and 2 months later someone came out with a small trencher and put in a second line about 6" deep.
/ When to have underground utilities marked? #34
I have left instructions with my wife to have the cable installer call me. Yes, they did not call me. Yes they did not bury the cable deep enough. Inches deep or less. First time I drag the pasture with a drag harrow, I will pull up cable, unless I pull up the cable by hand and bury it myself a foot deep. I need to keep that on my short list of things to do. The telephone people did not bury deep by the house. The loader guy snagged that cable when doing light rough grading.
/ When to have underground utilities marked? #35
If you hit a utility that's only an inch deep and did not call for utility marking, the repair cost will be on you.
I cut the phone line to my previous house with a sod cutter. They never buried the line, but the landscape company put sod down right over the top. I come along 6 years later and kicked the cutter right through it. Everything was supposed to be buried minimum of 18 inches. Didn't cost me a dime that time, but I'd never try it again, and certainly not when digging more than the sod.
/ When to have underground utilities marked? #36
in most states the contractor must call locators. each contractor should have his own ticket
/ When to have underground utilities marked? #37
Funny you mention that. They do patrol the big transmission lines from the air. Any new work in the vicinity they see, they pay you a visit to see what you are up to.
We were putting in a new tile outlet for the local farmer. Back when the tile was laid, they ran slotted across the fields but the last 20' was terminated with a solid PVC pipe if it terminated at a woods line, creek, etc that was near trees. 30 years of encroaching trees and roots get to the connection point at the start of the PVC pipe. That plugs the whole tile.
Was doing one just this year that was within ~20' of a ~40" gas main that runs through the area. We didnt call cause we knew we were just digging up the 20' pvc pipe and it was installed decades AFTER the gas main. and not very deep. So no chance of hitting the gas main, just following a 20' stick of PVC to dig out some roots.
they showed up a few days later to inquire what was going on:laughing:
/ When to have underground utilities marked? #38
Also, over the years (well after lines were placed) people will cut the grade down for many different reasons and not wanting to deal with the cost or time of lowering the line, they'll leave it shallow.
/ When to have underground utilities marked? #39
Here's an expensive example of what can go wrong.
2006 FREIGHTLINER COLUMBIA T/A 6X4 DAYCAB TRACTOR TRUCK (A59912)
2006 FREIGHTLINER...
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
2020 John Deere R4044 Sprayer (A63111)
2020 John Deere...
Caterpillar D8R/D9R Service Manuals (A63117)
Caterpillar...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
2015 Chevrolet Traverse SUV (A61574)
2015 Chevrolet...
