When to have underground utilities marked?
/ When to have underground utilities marked? #1
kingranch03
Grass Valley, CA
Kubota
Hi All,
Thinking about doing some tractor work for people asking for it but want to be cautious about digging on land I don't own and therefore don't know whats underground. Aside from all the other consideration I was curious to ask specifically what type of tractor work should a "customer" have underground utilities marked?
I assume anytime you dig with the backhoe say trenching, but what about when doing some box blade work, such as carving out a shallow (1' deep) diversion swale for example?
I am in a more rural area in Northern CA, where we are on wells and propane tanks, is it the land owners job to mark those lines? Similarly, who's responsibility is it to mark the power lines from the pole on the property - the land owner or the county/city?
For those of you doing this work professionally, do you take on the responsibility of calling the appropriate companies to have utilities marked or do you just tell the customer in the bidding stage that they need to have X,Y & Z marked before the work day?
Thanks in advance.
/ When to have underground utilities marked? #2
Whether pro or homeowner call if you plan to dig. You will be responsible if you dig wrong. Doesn't matter who calls. If no flags don't dig.
/ When to have underground utilities marked? #4
The only way to protect yourself is to call in a locate when you dig. In all cases I can think of it is the responsibility of the contractor to make the call. If the homeowner or a different contractor calls in the locates you still have to call in the locate to protect yourself. Most locates are good for two weeks, beyond that you need to call in again to renew it. There have been many a contractor put out of business because of not calling in for a locate, and all the utility companies can afford more lawyers than you can. Just do it.
/ When to have underground utilities marked? #5
In IL either the contractor or the home owner can call in the locate. I the land owner does it but isn't doing the work himself he has to list the contractor on the locate request. I do the locate call ins for my nephews stump removal business. I just file them online at the IL one call website. You will have something different in CA but should be similar.
They won't locate any customer installed utilities like water, sewer, or electric like to an out building. The utility will locate up to the gas meter, or electric meter, phone line normally to the residence, etc. Some utilities can be buried very shallow, like 2-4 inches in some cases for phone/cable, or gas in some cases.
Thanks all - it sounds like if you are going to go below the surface, regardless of depth, have it flagged.
/ When to have underground utilities marked? #7
If you hit a utility that's only an inch deep and did not call for utility marking, the repair cost will be on you.
/ When to have underground utilities marked? #9
Call EVERY time .
Technically, any time you break the surface of the earth, even on your own property. Lot of phone lines have been cut putting in mail boxes, sign posts, and fence posts. 811 is free, but might require you to white line the area you will be working in. Shovel, post hole digger ect account for roughly 50% of utility damages (by number, not dollar amounts)
As to when to call, they have two working days after you call. So, call Monday, means they have all day Tuesday and Wednesday to mark, and you should be ready to go on Thursday. Always make sure your ticket is 'clear' because some utilities might mark a special code such as "can't access" "need white lined" "high priority, must meet in field" ect.
Edit: if you cut anything, you figure best case is $500, and I've been walking next to a machine that mixed a $97,000 line.
/ When to have underground utilities marked? #10
Each state has different Laws and regulations concerning these locates. Look in the front of your local Telephone book and read about the locate requirements. They are published there in most municipalities as a consumer protection service. These rules are based on LAWS that have made an example of many contractors. When you call 811 in most areas they will give you a Locate Number and the Legal dig start time when your request will be valid! honor the time before starting work, but as a repairman for AT&T, I can tell you that the locate companies can be very slack. also when you make your 811 call, ask what the locate tolerance is for your area. In NC for example, the law says 30 inches each side of the marks, other areas may have different specifications. Knowledge of the laws can be very valuable. I have billed the Locators many times for missing the lines by 32 inches. They paid instead of the digging contractor! A camera is a Wonderful tool when used with a Tape measure, if you do accidentally hit something that is outside of the prescribed distance from the utility marks. A smart Phone is an even better camera, because it embeds the gps data as well as the day/date into the picture, and has been proved to be admissible as proof in most courts!
/ When to have underground utilities marked? #11
An inch?? Maybe you exaggerate a bit?
/ When to have underground utilities marked? #13
X2
Call before you dig.
If you hit something and it is not marked and logged that YOU/your company called; you are going to pay. The service is free in most states, maybe all of them. The repair costs are not free.
/ When to have underground utilities marked? #14
I install irrigation systems , I hit a fiber cable that was mismarked and it was an inch in the ground . I always take pics of the site before I dig to verify where the marks were . The locaters are quick to spray lines after a problem to cover their butts
/ When to have underground utilities marked? #15
Who is liable if they were marked wrong. My neighbor was doing a water drainage project in his yard. He called and had all of the utilities marked. The culvert under the county road was rusted out. He called them to come fix it. They came and fixed it. I watched the county backhoe hit the main gas line 15 feet from where it was marked. Lucky it went between the backhoe teeth and only scratched it a little and didn't bust it.
/ When to have underground utilities marked? #16
If it's marked wrong it's on the locator doing the marking.
In most places it's 2 ft on each side of paint mark (4 ft total) and whatever the depth the utility is does not matter. The locator is not required to give a depth so if it's marked and under a leaf and you hit it. It is on you.
/ When to have underground utilities marked? #17
If it's marked wrong it's on the locator doing the marking. In most places it's 2 ft on each side of paint mark (4 ft total) and whatever the depth the utility is does not matter.
It was certainly more than 2 feet off.
/ When to have underground utilities marked? #18
Hi All,
Thanks in advance.
Don't be like these guys. My lift line is marked. I told them it is shallow. I pointed out where it is. Then they hit it twice in as many minutes. I billed their boss $1100 after fixing it.
/ When to have underground utilities marked? #19
I was having a whole house of sheet rock delivered. I told them where the septic tank was and put saw horses over the tank. The bunch of dumb butts got out of the truck and moved them and drove over the tank.
/ When to have underground utilities marked? #20
As others say, its a good idea to call anytime. But most of the dirt work that one would encounter isn't going to be near anything they will mark. Water meter is usually near the road, and they only mark to the meter. Electric, if underground will only be marked up to the meter, not to the house. Well, propane, outbuildings, dog fences, irrigation, etc are All customer owned and won't be marked.
I have never hit anything other than phone lines before. And the times I have hit that, I have never called. Because it wouldn't have mattered when needing to run field tile through where the line was. Even if I were to get digging by hand, its easy to slice through phone line with a shovel. Never been charged for a repair.
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
1999 GENERAC 99A GENERATOR (A64280)
1999 GENERAC 99A...
2025 Swict 66in. Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
2013 BAD BOY AMBUSH RTV (A64280)
2013 BAD BOY...
