How do ramps calculate their load?
/ How do ramps calculate their load?
I went with these ramps: Ride Master Arched UTV Trailer Ramps 5'5" Long | DiscountRamps.com
Lightweight - 15 lbs ea.
5" spacing - for ZRT front wheels
Arched - so mower deck does not bottom out on edge of trailer
3,000 lb weight limit - no worries of overloading.
20 1/4" wide - for ZRT rear wheels
tie down straps included
Thanks for all the suggestions.
I'll pick up the golf cart in a few weeks and I anticipate no problems.
/ How do ramps calculate their load? #42
I went with these ramps: Ride Master Arched UTV Trailer Ramps 5'5" Long | DiscountRamps.com Lightweight - 15 lbs ea. 5" spacing - for ZRT front wheels Arched - so mower deck does not bottom out on edge of trailer 3,000 lb weight limit - no worries of overloading. 20 1/4" wide - for ZRT rear wheels tie down straps included Thanks for all the suggestions. I'll pick up the golf cart in a few weeks and I anticipate no problems.
Those should handle it no problem! Good job!
/ How do ramps calculate their load? #43
They look like great choice.
/ How do ramps calculate their load? #44
I think I have it narrowed down to this one. Tri-Fold Aluminum ATV Pickup Truck Ramps | DiscountRamps.com Criteria: wider than 50" but less than 60", spaces in ramp 3" or less (for front wheels of ZRT), at least 5' long, minimum 1500 lbs. weight limit, trifold. If I bypass the tri-fold these would work. Ride Master Arched UTV Trailer Ramps 5'5" Long | DiscountRamps.com Do I need tri-fold for the ZRT mower?
Don;
I think you made a good choice as the 1st one you linked to, with checker plate would have been problematic. I had a pair of aluminum ramps with checker plate surface. If it was even a little wet I had no traction to load my garden tractor. Turf tires are like drag slicks when wet or muddy.
Sent from my iPad using TractorByNet
/ How do ramps calculate their load? #45
I have a similar style of ramp I was using to load my BX2230 into a deck over trailer. Someone noticed that the plate lip that sits on the trailer deck was separating from the ramps. I think your ramps have three fingers that support the ramps on the trailer. Watch how those are welded. My welds to the plates were cracking after about 2 dozen uses. Jon
Ok, I keep an eye on the welds, good advice.
2018 HINO 338 4X2 S/A 26FT CDL REQUIRED BOX TRUCK (A59912)
2018 HINO 338 4X2...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
2014 Buick Encore SUV (A61574)
2014 Buick Encore...
2013 CATERPILLAR 305E CR EXCAVATOR (A64279)
2013 CATERPILLAR...
