How do ramps calculate their load?
/ How do ramps calculate their load? #22
If your wheelbase is longer than the ramps, as you describe, then the ramps will only see a portion of the vehicle weight.
You can chain an attached ramp at the same level as the trailer deck. It doesn't get in the way of hauling longer stuff.
Ok, I can see that working. If I can get the trailer side wall straight again, maybe. Have you seen any good plans for an add on ramp?
That's what I was thinking, but the weight limit at any specific point on the ramp is not listed. I would think the 1200 limit would be in the center and the limit going toward each end could be increased before failure. Any engineers out there?
/ How do ramps calculate their load? #26
/ How do ramps calculate their load? #27
With a 16" deck height a failure isn't exactly going to be catastrophic. I would try it and see what happens. You will quickly find out if you will need new ramps or not. You could even use the trailer jack to lift the tongue and make the rear lower if you wanted. You can even do this with the trailer attached to the truck and get a few inches which helps. We had to do this when loading a low mustang on a trailer.
That being said I got some defective aluminum ramps once. I was loading a four wheeler in the back of a tall dodge 4x4 truck. It weighed maybe 500lbs and I was 180lbs. I got a little over halfway up and one ramp busted. I was very lucky it didn't flip over backwards on me. They were 1,000 lb ramps. The bed was over 3' tall so it was scary.
/ How do ramps calculate their load? #28
Failure at 16" wouldn't be catastrophic, but why would you try it? At the very least you trash a set of ramps and then have to buy a proper set.
/ How do ramps calculate their load? #29
Maybe he is and maybe he isn't. I am sure that rating is for something totally on the ramps. With his long wheelbase on the golf cart I don't think he will apply all that weight to the ramps at once. I guess it depends on how long the ramps are but even if they are 6' his wheel base is is 75" so his front tires will be on the trailer before the rears touch the ramp so he will never be applying 100% of that weight to the ramps. For no taller then he is trying to go up I would get some shorter ramps maybe 4-5' unless the golf cart was super low profile.
/ How do ramps calculate their load? #30
I got my aluminum ramps from discountramps.com. They are awesome. Light and much less flex than the beaten old angle iron ramps that came with my used trailer. I recommend those guys for sure. Good product, good price, and shipped fast.
/ How do ramps calculate their load? #31
dstig1, The owners manual on the ZRT says the ramp should not be two separate ramps but one, that's why I'm looking for a tri-fold at least 50" wide. I found a lot on the link you provided and there is a 10% off black Friday sale! Thanks for the link. I have a lot of comparison to do.
/ How do ramps calculate their load? #33
I'm looking at a try fold ramp that is rated at 1200 lbs for my golf cart to go into my trailer. The golf cart is 1300 lbs. the wheel base of the cart is 75" so there will mostly be 2 wheels either in the trailer or on the ground and never 1200 lbs at the center. Do ramps calculate the max load at the center, and will the ramps be ok?
How to Load a Golf Cart Into a Truck | DiscountRamps.com You might consider checking out this website...it has a ramp calculator about the middle of the page...
/ How do ramps calculate their load? #34
txdon, So far we gave you 3 links to websites, and they are all the same site. :)
I like sites like that, which have a lot of good technical info to back up their products.
Yep, I realized that too after I posted, I thought it looked familiar. Excellent site.
/ How do ramps calculate their load? #37
I agree it would probably work, but why would you buy ramps that you know are too light? The cost difference between 1200 pound ramps and 1500 pound ramps is marginal. If he already had 1200 pound ramps I would say try it and see what happens, but he has to buy a set of ramps. IMO it is pretty dumb to buy something you know is is not rated to carry the load you plan on carrying.
/ How do ramps calculate their load? #38
I agree 100%. I missed that in the original post. I thought he already had some ramps. Yes if you are buying some by all means get the heavier ones but if you already had the smaller ones they likely would have worked.
/ How do ramps calculate their load? #40
Both of those look like very nice options. I think the tri fold ramps are recommended for z-turns due to the independent drive wheels and the nature of the beast. Z-turns can be turned off a ramp easily compared to most other mowers/4wheelers/etc. A solid platform (tri-fold) provides a safer and more stable ramp. And that trifold you selected looks nice with the semi solid surface. It would also work well for loading 2 wheel carts, and smaller things like tillers etc. However, if you might need to load heavier things in the future, I would go with your other choice. They are rated higher, and you are only using these short ramps on a trailer, not a pickup. To me, that makes things much safer as far as the z-turn and trifold concerns go.
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
KUHN GA4121GM 11' ROTARY HAY RAKE (A64277)
KUHN GA4121GM 11'...
2011 MACLTT  150 BBL ALUMINUM VACUUM TRAILER (A65643)
2011 MACLTT 150...
Caterpillar 446B Backhoe (A66285)
Caterpillar 446B...
2021 Kenworth T880 Tandem Dump Truck, VIN # 1NKZL40XXMJ464379 (A65563)
2021 Kenworth T880...
