Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread.... #541
Originally Posted by Xfaxman
Haven't found one too heavy. It would have to weigh over 4500 pounds. >
This one would have been close. Over 40 inches on the both ends and 11 feet long.
Yep, that is a big-un!!
When I moved this one to the burn pile I had the bigger, heavier Monster Grapple on the V417.
The rear got a little light when I extended the boom, guess I should have gone all the way out to see if the wheels would come off of the ground.
Too late to try it now. :D
/ Grappling fun - A Picture Thread.... #542
Got my WR Long valve installed today. Pretty easy job, not really 100% happy with the mount that was supplied with the kit. And the factory bolts that had to be removed to install the mounts, ended up being to short to re use. Other than that it is definitely a DIY job. Now need the grapple. ��
/ Grappling fun - A Picture Thread.... #543
Got my WR Long valve installed today. Pretty easy job, not really 100% happy with the mount that was supplied with the kit. And the factory bolts that had to be removed to install the mounts, ended up being to short to re use. Other than that it is definitely a DIY job. Now need the grapple. 😜
/ Grappling fun - A Picture Thread.... #544
LOL! Yes, the front left tire is the only one on the ground. It was a huge tree and it was straddling a fence that I didn't want destroyed. I was trying to hold the tree in the air before I cut the limbs that were taking the weight of the tree. I was hoping the skid would keep the tree from dropping. Well, the tree was too heavy! LOL!
Well it sounds like you were out of the cab and only had a good laugh vs. being in the cab and needing new drawers:eek:
/ Grappling fun - A Picture Thread.... #546
I repaired the cylinder mount that got torn off and I added some teeth. The cylinder mount wasn't installed properly the first time and was only half welded.
I decided to mig weld the teeth. I rolled the welder up and dang it out of gas. I had another cylinder in the shop so this was only a minor setback.
Teeth welded on.
So far I am impressed with the teeth.
/ Grappling fun - A Picture Thread.... #549
Fun, eh? Ten minutes of grapple work sure beats and afternoon of sawing and messing with brush etc.
That is not even a good testament for a grapple. That could have been almost as easily accomplished with a bucket and chain or pallet forks. 5 whole pine trees of this crap is another story.
/ Grappling fun - A Picture Thread.... #550
Grapple a tree: ten seconds. Ungrapple a tree: two seconds.
Use a chain and bucket: 1) dismount, 2) fight through the brush, 3) unwrap your chain from the storage bin or brush guard, 4) figure out how to get the chain under the bucket without crawling through poison ivy, 5) struggle to get the chain tight when the tree is only half in the bucket, 6) lift tree, move then dismount and re secure the tree for travel, 7) at destination dismount, unchain tree, try to keep tree from crushing you while you retrieve chain as tree is precariously balanced on top of bucket, 8) leave tree on ground, don't even dream of lifting it onto a pile unless you have a death wish, 9) return chain to storage, 10) remount tractor, 11) make note to self: get a freaking grapple.
/ Grappling fun - A Picture Thread.... #551
Yep, I like my grapple. Where the tree top came from and where I carried it was sooooooo easy with a grapple. It's so nice to not have to move off the seat of the tractor and move a top this size, no torn up yard or driveway from dragging it with a chain like I used to do. Another small job.
/ Grappling fun - A Picture Thread.... #552
Grapple a tree: ten seconds. Ungrapple a tree: two seconds. Use a chain and bucket: 1) dismount, 2) fight through the brush, 3) unwrap your chain from the storage bin or brush guard, 4) figure out how to get the chain under the bucket without crawling through poison ivy, 5) struggle to get the chain tight when the tree is only half in the bucket, 6) lift tree, move then dismount and re secure the tree for travel, 7) at destination dismount, unchain tree, try to keep tree from crushing you while you retrieve chain as tree is precariously balanced on top of bucket, 8) leave tree on ground, don't even dream of lifting it onto a pile unless you have a death wish, 9) return chain to storage, 10) remount tractor, 11) make note to self: get a freaking grapple.
With bucket hooks it isn't that hard. It still sucks and I don't recommend the method. A chain and bucket still beats an afternoon of sawing. I have a grapple, you don't need to convince me how nice they are.
/ Grappling fun - A Picture Thread.... #553
Nothing wrong with a chain and bucket, can't do without them in my case. I consider IT to be the the grapple expert on TBN and I don't think he was intending to offend you. If you are getting it done your way, more power to you and please share pictures. We always can learn from others.
/ Grappling fun - A Picture Thread.... #554
I did the chain and bucket hooks deal for years and got an 84" dial lid grapple about three years ago. I'm not going back. In fact, I may double down and buy a grapple for my 46 HP Tractor as well.
Sent from my iPad using TractorByNet
/ Grappling fun - A Picture Thread.... #555
That is a pretty good description of it.. I decided to get the grapple..:thumbsup:
/ Grappling fun - A Picture Thread.... #556
Been there, done that. Got the freaking grapple. :)
/ Grappling fun - A Picture Thread.... #557
My favorite T shirt:
2014 Ford Escape SE SUV (A61569)
2014 Ford Escape...
2014 JOHN DEERE 648H SKIDDER (A62129)
2014 JOHN DEERE...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
