Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread.... #521
A big load of brush can easily interfere with vision when driving. When driving in a field, I tend to stop every hundred feet or so, raise the load, check what's ahead then lower and drive a bit more.
I often drive backwards with big loads, for the reason you mention plus so that any trailing limbs hanging down don't get under the wheels and pull the load out of the grapple.
/ Grappling fun - A Picture Thread.... #523
yep, makes sense, thanks. so the only issue would be the constant switching back and forth. I can see where it would be nice to have dump/curl available all the time like setting a log on a mill or something. now to figure out the cost difference...
If you can do some basic plumbing you can add a diverter or third function valve yourself instead of buying an expensive kit.
I added a manual (vs electric) third function valve in 2011 for about $250 total. So I have one control for the FEL and one for the grapple. Both are active all the time and controllable with one hand.
Edit: Before I added the valve I ran the grapple off of one of the rear remotes which worked fine. But I wanted to free up the rear remote for a TnT cylinder.
gg
/ Grappling fun - A Picture Thread.... #524
Same thing I do, a lot easier and safer
/ Grappling fun - A Picture Thread.... #525
As long as you're not pulling over live, or worse, dead trees onto your head. I've done that a couple times hooking stuff with a wide load in reverse.
Even with 11gpm, I don't have enough flow to do two moves with any kind of speed unless I jack the throttle way up and even then it's not fast enough to think I'd be better off with a 3rd valve vs the diverter. We're talking tractors, not skidsteers that have ample flow for dynamic loader moves. True third function sounds great on paper, but the real world is another matter.
Before I added the valve I ran the grapple off of one of the rear remotes which worked fine. But I wanted to free up the rear remote for a TnT cylinder. gg
Good point Gordon. That would certainly be the number one disadvantage to using the the rear remote.
I added 4 rear remotes to my tractor thinking that way I would always have one extra, even if using top and tilt.
Now, I often have them all in use, and at times need to disconnect the side link to free up that port.
I could use 6 if I had them.
/ Grappling fun - A Picture Thread.... #527
Just wanted to say that the discussion in posts 501 through 509 of the basic differences between electrically-activated diverter and true third-function setups was one of the clearest and most succinct I've seen. :thumbsup:
/ Grappling fun - A Picture Thread.... #528
/ Grappling fun - A Picture Thread.... #529
I second this, it cleared it up for me.
/ Grappling fun - A Picture Thread.... #530
Fine to lift that high when static but lower that load before moving. Hit a bad hole while moving and you could go over with the load that high.
This reminds me of two advantages the V417 has, the fixed front axle is more stable with the load raised and I can extend the boom when brush is hanging close to the front wheels.
/ Grappling fun - A Picture Thread.... #531
My WR Long valve kit showed up today. Hopefully I will have time this week to install it and get a grapple bucket to go with it for the weekend.
/ Grappling fun - A Picture Thread.... #534
Again I submit Xfaxman should be banned for his posting of tractor ****.
Look at the thread title, what is more fun than tractor ****? :D
I agree ;) It just ain't fair that we all have to find a way to get around a problem like that, and all he has to do is pull on a lever and the problem goes away (about 10 feet away):laughing::laughing::laughing:
Now don't exaggerate, it only extends 5.5 feet. But that is usually plenty to not run over dragging branches.
If I am dragging something longer out to the side, I can set the rear wheels at an angle to offset the grapple farther away (to either side) from the front wheels.
/ Grappling fun - A Picture Thread.... #535
What happens when you try and pick up a tree that is too heavy.
/ Grappling fun - A Picture Thread.... #537
WHAT the ……..:laughing:
Is the front left tire of that machine on the ground? Looks like one of those "here, hold my beer and watch this" deals.
LOL! Yes, the front left tire is the only one on the ground. It was a huge tree and it was straddling a fence that I didn't want destroyed. I was trying to hold the tree in the air before I cut the limbs that were taking the weight of the tree. I was hoping the skid would keep the tree from dropping. Well, the tree was too heavy! LOL!
/ Grappling fun - A Picture Thread.... #539
Haven't found one too heavy. It would have to weigh over 4500 pounds. >
This one would have been close. Over 40 inches on the both ends and 11 feet long.
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A63118)
2023 Kubota...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63118)
2021 Takeuchi...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2016 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A62129)
2016 JLG ECOLIFT...
John Deere 5045E for sale
John Deere 5045E...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
