DIY tractor weights ideas
/ DIY tractor weights ideas
Me personally, I'd be reluctant to take the tire/wheels off the tractor. So,,,, let's assume you do and you lay them on your trailer. Then you pump 400lbs of fluid in them. They already weigh 150-200 lbs. Do you have a method to stand them up, get them off the trailer, and align them back onto the tractor?? If not, avoid this plan.
Not saying it can't be done. Just saying you ain't doin it by hand.
I was thinking about that yesterday! I'm just going to rent a trailer to tow my tractor that's the easy way not lifting a tractor tire up after more weights been put in.
/ DIY tractor weights ideas #62
Good plan!!!
/ DIY tractor weights ideas #63
taking huge tires off and on is done with a piece of plywood and grease. just shim the plywood to make a ramp to slide the tire off and grease the plywood to slide down the plywood. back up trailer to tire and lay down ,valve side up, and take to have filled. reverse process to install. if you can't stand up, make a-frame with come-a-long and winch to stand up or when laided down put 2x4 under tire as lever. did on backhoe by myself when loading my tires. takes some pre-thinkin'. allis backhoe weighs 15,000 lbs
rob
/ DIY tractor weights ideas #64
sorry, double post
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A59911)
2020 FREIGHTLINER...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
Freightliner Tender Truck - Adams Tender (A63688)
Freightliner...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
