PROPANE TANK OWNERSHIP
/ PROPANE TANK OWNERSHIP #71
I may have missed this in the conversation about tanks popping out the ground but the water level comes into play on this also. The higher the water level the greater the pressure on the tank. I am sure the type of the soil covering it also for certainly loose sand would not hold like heavy dirt.
On the tank getting too cold for gas to come out, boy that is an issue here in cold days with portable bbq cookers. You often seen dual or even more tanks being used together for that reason in the winter. Please note 30 F above is cold here. Have no doubt 40 below does not have issue. Yes we are cold this AM, dropped to at least 27F, burr. About our third heavy frost of the year.
The depth of water only matters until tank is completely submerged
/ PROPANE TANK OWNERSHIP #74
PhysAssist;4297190. We're seriously thinking of getting an automatic propane backup geneator said:
STAY AS FAR AWAY FROM SUBURBAN AS YOU CAN. They are horrible. Come fill your tank and then charge at least 1$ more a gallon than ''going rate'' then when you call they will drop the price 50c or so and act like they are doing you a favor. Think of all the older folks that trusted Agway that they are ripping off. Charged my 90 year old granny $4 a gallon for fuel oil when they charged me $2.10 when I called and complained. There is a class action suit against them.......
/ PROPANE TANK OWNERSHIP #75
Hi Clint,
We are kind stuck with them for the tank we inherited when we bought the place, but I appreciate the info, and will look into the class action.
Thomas
/ PROPANE TANK OWNERSHIP #76
Hi Clint, We are kind stuck with them for the tank we inherited when we bought the place, but I appreciate the info, and will look into the class action. Thomas
Don't know your needs but if you are planning on refilling a leased tank for more than a couple years you may want to run the numbers on lease vs. buy. Conservatively figure at least a buck more a gallon plus the tank rental vs. buy. Also check new vs. used tank pricing. I think they try to scare you with lines when you suggest buying like, "well... you will be responsible for maintenance". What maintenance? I brush the evergreen needles and twigs off of it once a year so. Check the dial quarterly for a refuel call.
/ PROPANE TANK OWNERSHIP #77
I was on auto fill and free lease . A few years ago I got sick of them and told I would pay rental fee and to not to refill it. Sure enough they come and fill it . Then they say I had to pay their outlandish price per gallon and if I want them to remove the propane they would pay me half of what they charged me. I then promptly padlocked the tank so they could not fill it. Sure enough they came again to fill it after I told them not to and found it locked. They gave me crap about needing access to the shut off valve even though you could reach in and turn it through a hole. I then made a cap with an access hole for the valve and left it locked. Sure enough they came again and tried to fill it and found it locked. I was home and the driver said he could legally cut it off. I told him he most certainly could as long as a law enforcement officer was present. He left and that was the last time they came. Funny thing is they never came to get their talk and I rolled it into the woods.
I would do anything I could to get rid of that tank. Run it dry and buy a 100# tank to use until another company can set a new one.
/ PROPANE TANK OWNERSHIP #79
I worked for Amerigas for 20+ years. This sounds like something they would do. They sometimes installed underground tanks on a 10 year lease - purchase agreement during which time you agreed to buy from them exclusively. However, they typically didn't keep very good records as to the date installed. Often times they don't even have record of the contract. I can tell you from experience that if the district can not show you a contract or lease agreement, the tank is yours! Even if they did the installation, they can't show ownership. Do you have the sales recept for everything you own? Do you think the courts would allow a retailer to repossess any other item in your possession without their being able to prove ownership? Not a chance. This is an attempt to force you to buy their gas.
Don't worry about underground tanks "wearing out". If it was installed properly and has adequate protection from galvanic corrosion (an anode bag) your're good to go. It's a simple five minute test to determine the strength of your anode. Most any public utility or reputable propane dealer can do it for a minimum charge.
Good luck.
/ PROPANE TANK OWNERSHIP #80
We rented tanks for the last 10 years...didn't know any better. Our last fill with Suburban they left a bill and want $6.02 per gallon! That was about 5 years ago. Called to complain and with no questions asked the rep offered to lower the price to what we had paid for the previous fill, which was$3.25. As soon as the check cleared I called to stop regular deliveries and had them pick up the tanks when they were almost empty. We then leased tanks from a different supplier for several years...STILL didn't know any better.ast year we bought tanks from a local Amish guy who sells tanks all over the Northeast. Now instead of $3 a gallon we are paying around $1.25 for the same gas from the same supplier. Shopped prices and he turned out to be the cheapest in our area. Tanks will probably pay for themselves by the end of the winter.
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
17601CFL (A59228)
17601CFL (A59228)
Giyi GY-TB47 Forklift Telescopic Boom (A60463)
Giyi GY-TB47...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A60736)
2017 FORD F-150...
1979 HEIL TRANSPORT TRAILER (A60736)
1979 HEIL...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A58214)
2018 LARK UNITED...
