broken vice qustion
/ broken vice qustion #21
Thanks a lot for the info yeah its not worth it. Next vice will be a wilton
I have that same vice but it is 20 years old and the part that broke on yours s solid on mine. I also have a nice Wilton that is my go to. My dad procured it many years ago from the back of a work truck that was being scrapped.
/ broken vice qustion #22
Vintage craftsman vise's were made by Columbian, Reed or Wilton and can be a quality inexpensive alternative when looking for a vise, I have a large 5x8 Reed with the Craftsman badge on my welding bench that has been put up with a lot of work.
/ broken vice qustion #23
Those Wilton "bullet" vices are really strong and long lasting, I think they started making them in the 40's...
I have one here that my dad left me, I don't remember a time when we didn't have it here on the farm and it's been in use ever since...
SR
/ broken vice qustion #24
Up here in Canada the most common vices available used to be Record and Woden, both made in England.
This is a pic of my Woden vice broken and repaired by brazing over 50 years ago by our on-farm mechanic. Still use it to this day.
Terry
/ broken vice qustion #25
Should put this over in the HF tools that suck thread too :rolleyes:
I had a really cheap 4" Chinese vice I bought for my Maine camp from a cheap tool store. First time the body was struck a huge chunk broke off of the back piece. I think it was made of Bondo :laughing:
And I had Craftsman branded one I returned after purchase it was so poorly machined the jaws weren't even straight. :eek:
But..I have had this 6 inch vice I bought from the old Central Tractor that used to be around here so its been while, at least 20 years (or even more?)
I did internet search and it is a YOST utility vice and best I can tell it is the 906AS. There is also a 936AS model that specs just slightly smaller and cost less. I see TSC has them both online as does Amazon (and with fairly decent reviews). I have beat on mine for years and nothing broke or bent. I remember paying around $75.00 for it at the time.
Vises | Workbench Vises | Machinists Vises | Bench Vises | Combination Bench Vises
Makes me proud to have scored that old Athol Vice for $40.00 at the Flea Mkt. :D
Not as big as the Yost 906AS only 3.5 inch jaw width and doesn't swivel but has a serious depth when open
I would really like to put a manufacture date on THAT one. I posted it in this thread. http://www.tractorbynet.com/forums/...hol-machine-company-5-vise-3.html#post4279398
/ broken vice qustion #26
Here is some shots of my HF vise. Notice the solid castings and not the light hollow ones
And here is my good vise
/ broken vice qustion #27
Parker is another great old brand if you can find them.
/ broken vice qustion #28
SR
Best vice I've ever used!
/ broken vice qustion #32
I broke my 6" vise in the channel part 10 years ago, I went to the welding supply store, bought some 1/8", 11018 stick rod, I v it all out, shined it up, looked like cast iron. Then started welding, had to pause here and there because it got hot, tried to keep it under 300 degrees, lost count of the rods but probably used 2 lbs. or so, still using the vise today but I no longer put a pipe on the handle, hand tighten only.
I'll have my new wilton vice 6" by end of the week!. I should of known better then to buy a vice at H.F. most of there stuff is MADE IN CHINA JUNK!.
/ broken vice qustion #35
I bought a 5 or 6" HF vise about 15 years ago and beat on it and used it a lot and has worked out well for me.
Last summer I bought another 6" HF vise when near a store and installed it and the difference was amazing. Just the weight was half of the older one. The jaws section that clamps the material was quite a bit smaller in square inches and the throat of the face is way lighter duty. Glad I got an old one. I don't think I will pound on the new one after reading these comments.
Butler MFG Water Tanker (A63688)
Butler MFG Water...
2014 Ford Focus Sedan (A61574)
2014 Ford Focus...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63689)
2023 Kubota Z412KW...
Container (A61572)
Container (A61572)
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
