greasing tie rod end
/ greasing tie rod end #1
mez
Sault Ste Marie Ontario
L3800 HST
I have done my 50 hr service lube and grease on my L3800 HST, but cant seem to get grease into the right tie rod. I even changed out the fitting. all other fittings are fine. any ideas?
/ greasing tie rod end #2
Take the weight off with the loader and turn the wheel all the way to the left so you can get at it & try again.
/ greasing tie rod end #4
Another option is to get someone else in the seat turning the wheel back and forth while you try to pound the grease to it.
/ greasing tie rod end #5
Take your fitting back out and use a small pick or nail to clear it. It may have something left in thee from when it was made
/ greasing tie rod end #6
Buy this tool, load it with mineral spirits, clean that joint out and degrease it. The tool will force the mineral spirits into the ball joint and break down the crustified grease allowing new grease to be able to lube up the joint. Alternatively, you could try nailing the joint with a heat gun in an attempt to liquify the crusted grease in the joint in order to allow new grease to flow in and lube it up.
Amazon.com: Innovative Products of America 7862 Grease Joint Rejuvenator: Automotive
/ greasing tie rod end #7
Try loosening the grease fitting, had a car before that when the fitting was snuggled down wouldn't allow grease in but a turn loose and no problem.
/ greasing tie rod end #8
There is at least one fitting that makes pumping grease into impossible, on every new machine I've bought so far. If it's not on the machine, it's on the mower deck or the FEL.
I got this tip cleaner that'll work for what you need to do. You can pick it up everywhere..
Powerfist Oxy-Acetylene Universal Tip Cleaner | Princess Auto
2018 Nissan Versa Sedan (A61574)
2018 Nissan Versa...
case 370 glass door never installed (A61307)
case 370 glass...
2007 John Deere 1790 Planter (A63111)
2007 John Deere...
John Deere 7410 (A64119)
John Deere 7410...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
Adams Tilt Trailer (A63688)
Adams Tilt Trailer...
