Tires Questions before loading tires with water
/ Questions before loading tires with water #1
Roger_H
California
Kubota/L-2800
Hi all,
I've been reading the posts about "loading" tires with water with a lot of interest. I love my tractor (Kubota L-2800 with front loader), but if I get a good load of gravel, dirt or even manure (but not as bad since it's lighter) in the loader I can really get the back wheels to bob up and down over bumps, even with my box scrapper on the back. Putting water in the back tires to help trim that out seems like a natural for a little extra ballast. I ran into a local guy over the weekend that's done this with his own tractor tires. He says he got an attachment from NAPA for his house water hose and filled the tires up straight from the spigot.
I've got a few questions first:
1) Is there any special additive you need for the water to keep the rubber in the tires from degrading? Does it actually damage the rubber at all over time?
2) Do regular tire pressure gauges work for determing the water pressure in the tire?
Are there any other special considerations I'm missing before I attempt this?
Thanks!
Roger
/ Questions before loading tires with water #2
Liquid ballast is probably a good idea, but straight water will be very hard on your rims, when we had the farm, we ran tubes and filled the tubes with a calcium water, any time we had a leak it was a mess. Straight water will freeze thats why the calcium additive. I have heard of guys here using windshield washer fluid... I think that after a while, the alcohol or what ever chemical will evaporate, my grandfather always had extra windshield washer fluid bought at the end of season on sale and after a year or so would freeze in an unheated shed, so I'm not personally convinced that washer fluid is fullproof either. I know that there is an alternative product on the market that others here have used, the name escapes me right now, but i know it will come up in a search.
Other things to look at if the liquid ballast doesn't end up serving your purpose, are the different varieties of TPH ballast boxes, and or wheel weights and a TPH weight bar.
good luck
/ Questions before loading tires with water #3
Hi Roger,
You don't need an additive for keeping the rubber healthy. But if your area is subjected to freezing temps then you most definately need a liquid that will not freeze. I use "old style" radiator fluid in my tires.
Depending upon the type of fluid you select, you may or may not need inner tubes. Any sort of salt solution will require inner tubes. The salts will eat the steel rims. Sugar-beat juice (sold around Michigan) won't eat the rims. Ethylene Glycol (old style radiator fluid) won't eat the rims. Plain water might cause rusting over many years.
Tires with a solution of salts or sugars will be heavier than the radiator fluid or water approach. Some folks use windshield whiper solution.
To measure tire pressure with liquids, you will need a liquid capable pressure gage. I got mine from Gemplers.
I too have a hose attachment. It leaked but it worked. I don't think it was made very well. The job isn't very hard to perform.
Good luck.
/ Questions before loading tires with water #4
Rotate your tire to the 12:00 position and fill away, this will fill the tire to 75% capacity, relieve the pressure every few minutes..your tap water pressure will exceed the tire pressure rating.
Always check your tire pressure at 12:00 position.
I used windshield washer fluid in my tires to keep the freezing temp lower. The R4 tires will hold 29.5 gallons each and add 500lbs to your rear.
Filling your tires will smooth out your ride a little also.
Thanks for the reply. I get how to hook up my hose to the tire to fill it up. How would I get other liquids into it, such as anti-freeze? Pour through the hose? I don't have a way to pressurize it separately from the water if it needs pressure to make its way in.
I don't live in an area that's subject to heavy freezing. I _could_ frost, but that's a rare instance.
Roger
/ Questions before loading tires with water #6
I put 100% wiper fluid in mine, good to -20F. Your talking 60-70 dollars. You could calculate the amount of water and fluid to protect to a high temperature but I highly suggest you just use straight wiper fluid. Mix or place the fluid in a container that holds 30 gallons (twice) to fill each tire and pump from the container!
/ Questions before loading tires with water #7
To measure tire pressure with liquids, you will need a liquid capable pressure gage. I got mine from Gemplers???????
Pete do you use a special gage to check tire pressure /forums/images/graemlins/confused.gif i have loaded tires and use a standard gage at the 12 o'clock position /forums/images/graemlins/confused.gif
/ Questions before loading tires with water #8
Eric, you can use a regular air gauge, but it probably won't last long. I've used one by having the valve stem at 12 o'clock, but I always also got my air hose and gave it one short blast of air first to try to blow any liquid out of the valve stem. The price on air/liquid gauges isn't much different than the price on regular air gauges, so I think they're a good investment, and I think nearly any auto parts store has them, as well a tractor dealer, Tractor Supply Co., etc.
/ Questions before loading tires with water #9
thanks for the info bird. i will pick one up next time i drive by an auto parts store or tractor supply store /forums/images/graemlins/grin.gif
one thing i noticed is beet juice sure gets sticky /forums/images/graemlins/tongue.gif
/ Questions before loading tires with water #10
To put the anti-freeze in I cut an old hose, put a funnel on one end and the other end screwed to the little NAPA thing. It goes in slow but it goes in. I did mine before I put the water in so I would have less pressure build up and it went in faster.
/ Questions before loading tires with water #11
I used a 16gal 12v tow behind sprayer, the connections were the same size as a garden hose.
/ Questions before loading tires with water #12
I'm looking to do this as well and I understand the process. What I can't decide is what fluid/additive to use. It might rarely drop into the 20's here so icing isn't the biggest issue. I'm most concerned about what will be safest for my rims. What will be less likely to corrode the rims, pure washer fluid or water plus radiator fluid? If radiator fluid, which proportion?
/ Questions before loading tires with water #13
My dealer used one gal. of antifreeze in each rear tire, so that's what I used. Didn't have any problem last winter which was the first for my tractor. Tubes came on mine but they are not necessary.
/ Questions before loading tires with water #14
Stupid question: How do you know if you have tubes or not?
/ Questions before loading tires with water #15
</font><font color="blue" class="small">( How do you know if you have tubes or not? )</font>
By looking at the valve stem, but since there are several types, I'm not sure I could adequately describe what to look for without pictures.
/ Questions before loading tires with water #16
All posts are well intentioned. IMO beet juice (rim guard) is much better than anything else. non corrosive, freezeproof to minus 35 F. Lasts forever, preserves inner tire..is non toxic and biodegradable. It is made from sugar beets. Will not corrode rims. You can have it installed in situ by most tire shops for reasonable cost (ie 300 per wheel pair). The only way to go. Filling tires is not child's play, nor easy. NEVER use calcium chloride. It will destroy your rims fer sure. WW fluid costs more than beetjuice, weighs less by far.
Another way to go is to place a weight box on the TPH. Easy to make, easy to use, but harder on the tractor frame and rear axle. GOOGLE FOR DETAILS.
/ Questions before loading tires with water #19
WW fluid costs more than beetjuice.
You were doing soooooo good til you got to this. So wrong. WW fluid is half the cost of beetjuice. :)
/ Questions before loading tires with water #20
OP has option to use plain water due to his climate. 0 cost and env impact. No special equipment needed to fill or empty. ... Not as heavy as the expensive stuf tho.
Yep. No brainer to me.
445 (A63290)
445 (A63290)
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
LOAD OUT AND SHIPPING (A65579)
LOAD OUT AND...
Year: 2003 Make: International Model: 4300 Vehicle Type: Truck Mileage: 2,048 Plate: Body Type: T... (A61573)
Year: 2003 Make...
2009 VOLVO VNM 300 6X4  T/A DAY CAB TRUCK TRACTOR (A59906)
2009 VOLVO VNM 300...
2018 Dodge Journey SUV (A61574)
2018 Dodge Journey...
