JD 59 inch snowblower
/ JD 59 inch snowblower #1
gaffneymj
Wisconsin
John Deere 855
I have a 59 inch snowblower mounted on a JD 855 tractor. I recently saw a device that would keep the Hydraulic hoses off of the front wheel. It was a rod with the top bent into a circle to hold the 4 hoses. It was mounted to the frame, I believe. My local JD dealer tells me they are not available. Hmmmm. Anyone have any info as t where I can find this accessory?? Thanks much.
/ JD 59 inch snowblower #2
Sounds like it should be easy enough to make your self if cannot find it.
/ JD 59 inch snowblower #3
I just made one for my 4410. Painted it black and it stays on all the time. Just pick a frame bolt in a good location and install it there. Sometimes you need to replace the bolt with a longer one to maintain enough thread engagement with a bracket installed. I made mine with a spiral shaped circle so that I didn't have to thread the hoses through. I just bend them through the spiral.
Thanks everyone for your rapid response. I have decided to manufacture my own for a custom fit.
/ JD 59 inch snowblower #5
Interesting response from the dealer. :) JD offers various sizes of those supports for the X-series, 1-Series, 2-Series and 3-series. How could he possibly not know that? One came with my 2720 and 54" front blower but I purchased additional ones to support my spout control. They come in very handy, can easily be bent to fit and they don't rust.
Most of them are $5-$15.
I even purchased a smaller one that was for a X700 garden tractor. I use it on my Land Pride hydraulic rear blade to help support the hoses and keep them routed properly.
/ JD 59 inch snowblower #6
I bought a 59 inch blower for 855 new. It did come with this part. But, simple enough to manufacture.
/ JD 59 inch snowblower #7
The part numbers are M115846 and M134828, but together would be over $50 from greenfarmparts.com
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
1983 John Deere 2940 Tractor (A62613)
1983 John Deere...
John Deere Quick Hitch (A64127)
John Deere Quick...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
