welding on a kubota b9200
/ welding on a kubota b9200 #1
sebes
Member
elida ohio
kubota b9200
I recently bought a Montana loader to attach to my Kubota 1989 b9200. There will be considerable fabrication with this project. Most of the welding will be done off the tractor but I see myself doing some tack welds during the fabrication process. My concern is damaging the electrical system if I tack some pieces while on the tractor. Your thoughts and advice would be greatly appreciated.
thanks in advance
Mike
/ welding on a kubota b9200 #2
Disconnect the battery, and keep the ground clamp as close to the area you're welding as you can.
/ welding on a kubota b9200 #3
I bought one of these Antizap Surge Protectors, but haven't used it yet. Some of the guys over on Welding Web swear by them.
/ welding on a kubota b9200 #4
How Does That work ?? Never seen one before . As always , You teach the rest of Us Something New :thumbsup:
I second the disconnect Battery . Some Don't but what is a couple of minutes for the added security .
Fred H.
/ welding on a kubota b9200 #6
i used to have a b6200 with loader, backhoe and i stick and mig welded on it all the time. there are no electronic 0n it except possibly in the alternator. i did body work in dealers since 1976 and the older machines didn't have) electronics. if you don't want to disconnect the battery(which) is the best way, just put your ground as close to your weld as possible. path of least resistance. rob
/ welding on a kubota b9200 #7
Don't know, haven't used it yet. Electronics are way above my pay grade!:laughing:
Here are the instructions on the back.
I've had two diesel powered cab & chassis dual wheel trucks. A 2004 F-550, and a 2007 1-ton Dodge. In the instructions to the up fitters. Both Ford and Dodge say just disconnect the batteries before welding on their trucks.
Thanks so much for the great advice
/ welding on a kubota b9200 #9
thanks in advance
Mike
NO electronics at all on that tractor. - No worries unless you are literally welding on the dynamo alternator.
/ welding on a kubota b9200 #10
I agree put the ground as close as you can to where you are welding and make sure it is a good ground. I never unhook batteries. I was welding stuff on to the flatbed in my 2016 Denali last week and I welded a lot on my 2015 F-250. Lord knows they have tons of electronic crap. I welded for several hours last week as well on my 2012 backhoe which also has a bunch of electronics. Never had a problem and never unhooked a battery and I have welded on virtually every vehicle I have had.
Every muffler shop in America welds on exhaust systems all day long and I have never seen them unhook a battery. Every welding rig I have seen welds up stuff on their flatbed and they don't unhook batteries.
It certainly won't hurt anything unhooking the batteries by I personally don't and I really don't even understand how unhooking them would even help anything.
/ welding on a kubota b9200 #11
We never unhooked batteries, just to weld something in the body shop either.
Over several decades, of doing this, no damage occurred.
Anything is possible, but I never saw it happen first hand.
/ welding on a kubota b9200 #12
checked with a buddy that works at a new car dealership and he says it is a MUST to disconnect battery cables now a days and some makes and models both cables disconnect both cables and air bags. have you ever had air bags go off when car was sitting still, not running when the bags went off? not pretty
/ welding on a kubota b9200 #13
I am not denying that is what probably all the manufacturers say. I am just saying I personally have welded on 2015 Fords, 2016 GM's, and 2012 Dodges as well as numerous older things without ever unhooking the batteries and nothing ever happened.
/ welding on a kubota b9200 #14
Back in the last millennium, while in high school, I was in welding class when i heard a pretty load boom. A guy welding on his motorcycle blew up his battery. I don't recall how he had things hooked up though.
/ welding on a kubota b9200 #15
I have welded on hundreds of cars with air bags, never had one go off. Never had one go off in our shop, at all.
During my certification, I was told an air bag can theoretically go off, while carrying it across the shop, from static electricity. Never saw that happen either.
They also told us, that you couldn't switch a cars a/c system from R12, to R134, without flushing out ALL the oil. Because, the PAG oil was not compatible with any of the mineral oil from the R12. As cars got older, and people did not want to spend a lot of money on them, so shops started just swapping everything and not flushing it. And, everyone found out, it worked just fine.
If the dealership wants to require the techs to do something, it's their money, they have that right. Nothing wrong with an over abundance of caution. But, it's not always necessary.
No manufacturer recommends jacking up a car without putting on the emergency brake either. I guarantee you that dealership does not require their techs to do that.
/ welding on a kubota b9200 #16
just to note, i have burned out a couple of radios and computers on cars that the battery was still hooked up and that was in the mid to late 90's. that was mig welding with the ground clamp darn near on top of the weld. in the early 2000's welding on a full size dodge car, cant remember make, fried computer with just ground disconnected. could have been coincidental. luckily every dealership has taken care of fried parts. on a tractor or anything, it only takes a minute to unground. a lot easier and cheaper than having to replace parts.
/ welding on a kubota b9200 #17
I always just unhook the battery for piece of mind. I also use a double ground. One for the weld and another to earth. I's just what I do. never had a prob.
