Engine Ran Backwards - What Now ??
/ Engine Ran Backwards - What Now ?? #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I was using my winch this morning and just about stalled the engine but she took right off again as soon as I disengaged the winch clutch. I was wearing hearing protection so I didn't really hear but more sensed something was different. Probably took me most of a minute maybe a little more to figure out it was running backwards and shut it down.
I restarted it and it is like nothing happened.
Is there anything I should tend to because of that. I assume it must suck air thru the exhaust and exhaust thru the air filter but am not at all sure on that.
Thanks
gg
/ Engine Ran Backwards - What Now ?? #2
When an engine runs backward, the oil pump also runs backwards meaning your bearings etc. got no pressurized oil. Most engines will not suffer any significant damage in a minute or less.
/ Engine Ran Backwards - What Now ?? #3
That is bizarre. Seems to have self corrected. Should not need to do anything else. It still drew air the same way. Only way it could get fuel. Must have been a pre-ignition in one cylinder to get it started backwards.
/ Engine Ran Backwards - What Now ?? #4
Back in the early 80s I use to be a driller on land rigs. Once when I going in the hole with the tubing string, came off the slips, started slacking off the string before the clutch disengaged, it killed 2 V12 Detroit Diesels, spun them backwards and they fired off, oil was coming out of the breathers, I ran over shut them down, checked the oil level and restarted, we never had any problems afterwards. Detroits are 2stroke engines and fire off pretty easy, may be different with a 4 stroke
Thanks for the replies. I guess lunch is over and what is done is done. Oil pump running backwards doesn't sound to good. At least I was at low rpms. It was bizarre to pull the winch rope and have the cable stream out instead of being pulled in. The tension in the winch cable must pull the engine over backwards like a recoil starter thru the pto when it looses power ??
Stopping 2 V12 Detroits - yikes
gg
/ Engine Ran Backwards - What Now ?? #6
I have it happen with other engines... like Model A and Model T Fords.
No harm if everything is lubed up and for a few moments...
Oil/Lube is the immediate issue.
/ Engine Ran Backwards - What Now ?? #7
My neighbor was digging with the fel on his Deutz CUT. He lugged it down and clutched it just at the point of killing it. The engine revved up again, but the rain cap slammed shut on the vertical exhaust. He throttled it down and shut it off, restarted, and continued working like nothing happened. Essentially, nothing did.
/ Engine Ran Backwards - What Now ?? #8
You might look at your air filter and make sure it isn't black from the soot. Older Detroits and some Macks were bad for running backwards.
/ Engine Ran Backwards - What Now ?? #9
I've had a couple old 2 stroke Detroit's and a 3408 Cat run backwards on me before.
Nearly stalled them, caught it will the clutch at the last second and the engine kicked and started up backwards.
Shut them down/restart and go.
/ Engine Ran Backwards - What Now ?? #10
Only had this happen once. Chrysler slant six in an older delivery truck that we were beating the snot out of. Shut er down and fired it back up with no problems.
/ Engine Ran Backwards - What Now ?? #11
Gordon, as long as the tree you just cut down didn't stand back up, you'll be ok.:laughing:
I did this 30+years ago with a little Kubota. Suddenly, I had 4 reverse speeds, and 1 forward.
I didn't give it a chance to stand back up. When I pulled the winch rope and the cable started pushing the log back towards the stump I shut off the tractor so I wouldn't have to cut the tree down again.
gg
/ Engine Ran Backwards - What Now ?? #13
Back when I was a kid working at a stone quarry my "ride" at work was a Euclid dump truck. One day I didn't pick a low enough gear for a hill and it died on the way to the top. The truck was loaded and the brakes didn't hold. Using the brakes on that thing was almost like dragging your foot on the ground. Next thing you know, I'm headed back down where I came from. It acted like I somehow got it in reverse without shifting and the engine sounded really odd. It was running backwards for a brief time and blew oil from the oil-bath air cleaner all over the fender. After the mechanic refilled the air cleaner he sent me on my way.
Informational Lot - Shipping (A63688)
Informational Lot...
1996 Vermeer V-3550 Ride-On Trencher (A61572)
1996 Vermeer...
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
2025 Swict 60in. Bucket Skid Steer Attachment (A61572)
2025 Swict 60in...
Topsoil Trommel (A57453)
Topsoil Trommel...
HARDEE 5' ROTARY MOWER (A63291)
HARDEE 5' ROTARY...
