Just starting on the tractor learning curve...
/ Just starting on the tractor learning curve... #1
ClaySlayer
Huntsville, AL
Kubota L3301
Hi all,
In the process of purchasing a ~12 acre tract with a ~1 acre pond so trying to get smart on tractors...because my little 15hp, 38in LX178 isn't going to cut it! LOL! The property is mostly wide open with any trees contained to the boundaries. Probably looking at a compact in the 30-40hp range.
/ Just starting on the tractor learning curve... #2
Hi. Welcome. Congrats on the property.
/ Just starting on the tractor learning curve... #3
Tell us what tasks you expect your tractor to perform.
Have you prior tractor operating experience?
Do you have the skills to do your own tractor maintenance and repairs?
How are you going to utilize your ten open acres? Pasture? Crops? Orchard?
Any rockets on your land?
/ Just starting on the tractor learning curve... #4
Welcome to the forum! There is a ton of knowledge from all the members. The search function is a great tool and provides hours of reading.
/ Just starting on the tractor learning curve... #5
Hi all,
Tractor: 30-40 hp (engine), hydrostatic tranny, 4WD, power steering, ag tires with rears filled with liquid, dual rear hydraulic remotes, front end loader (FEL) with 5-ft wide bucket, skid steer quick attach on the bucket, chain hooks on the bucket.
Mower: 5-ft brush hog.
Good luck
Mainly grass cutting and maintaining the area around the pond as well as a small (100' x 100' max) garden. We haven't decided exactly on where to put our house so maintaining a gravel driveway could be in the cards. My son and I also enjoy RC trucks so I'll probably try to build a small track off in a corner. Nothing really hard core...and no critters planned other than dogs. The property is fairly flat except for a small rolling hill (MAYBE 2% slope) at the back. It was used as a cow pasture for several decades until about 5-10 years ago so the vast majority of the property has a barbed wire fence around it but I don't foresee having any use for it so will probably remove most of it.
I don't really have any experience driving a tractor. I do maintenance and most repairs on our trucks and small engines so while I don't have any experience working on a real tractor I plan to learn and perform everything that I can.
It's a rainy day here so plan to spend some time searching and reading on the site. Thanks!
/ Just starting on the tractor learning curve... #7
G'day Mate and welcome to TBN from Downunder.
Enjoy the site.
/ Just starting on the tractor learning curve... #9
Seems about right.
FLUSHER has given good advice:
Tractor: 30-40 hp (engine), hydrostatic (HST) tranny, 4WD, power steering,
front end loader (FEL) with 5-ft wide bucket, skid steer quick attach on the bucket, chain grab hooks on the bucket.
I would differ only in recommending UNLOADED R4 Industrial Tires, rather than LOADED R1 Ag Tires, as you will want an FEL and the potential for turf mowing around a home is there. I do not remember clay as being the dominant soil type around Huntsville and, as a non-farmer you can delay tractoring a day or two if the soil is too wet. (Tires are always a close call.)
You will probably want a PTO powered roto-tiller and a 3-Pt. mounted cultivator for your garden.
Huntsville is a pretty affluent area. I expect you have a wide choice of tractor dealers not far from your property. With transfers in and out of Redstone Arsenal I expect used low hour tractors become available regularly.
One caution: Stay away from the pond. Ponds suck in tractors.
Here is an IMPLEMENT LINK: http://www.lsuagcenter.com/NR/rdonl...45263BDD8/11557/pub2917tractorimplements1.pdf
Alabama and Mississippi are home to most USA implement manufacturers.
/ Just starting on the tractor learning curve... #10
If your gravel driveway will be long enough to justify a dedicated maintenance implement your choices would be:
LPGS - Land Plane/Grading Scraper
Box Blade or Rollover Box Blade
Rear/Angle Blade
Heavy Landscape Rake
If you eventually decide to convert the pasture to something else, you will likely find it extremely compacted from hooves. You will probably have to plow it.
/ Just starting on the tractor learning curve... #11
:welcome:
I'm going to move this thread on over to the buying, pricing and comparisons section so we can keep it going.
/ Just starting on the tractor learning curve... #12
Welcome to the forum. How much are you willing to spend on a tractor.....are you looking new or used???
Thanks for the kind words and advice!!! Been quite a while since I started this thread so here's an update...
-Closed on the land in mid Dec.
-Knocked up wife in Jan with baby boy #2 (due late Sep) so now I've pushed my tractor timeline to the right till probably this winter or next spring. Want to make sure the little guy gets into this world ok before we make a tractor purchase.
-I rented a JD 4105 with a FEL and 5' cutter for a weekend about 3wks ago and cut the whole thing as well as filled in several holes that were left from downed trees and previous perc tests. As expected the FEL part took a little bit to get the hang of but I got a few hours of experience and was able to get the job done.
-Went ahead and ordered this past week an 81" X 20' car hauler (18 + 2) with 5.2k axles/brakes partly because I need the extra length (vs rentals and a buddy's 18') to lighten the tongue weight on my F150 and partly because you roll the dice with trailers that belong to buddies or rental places as far as quality/reliability/etc plus I'll need it eventually when I purchase a CUT and will add removable sides for more utility. I'll also probably go ahead and order a WD hitch too just to be on the safe side. I've got max tow on my truck but it's still a 1/2 ton when it comes to handling tongue weight so better safe than sorry is my motto. Power was plentiful when hauling the 4105 and cutter but the tongue weight was a little hairy.
-Will plan to just keep renting a tractor every 6-8wks to cut the majority of the land and do some loader work here and there and been using the little mower to keep a few places around the pond accessible for fishing. There are several rental companies near me and I'll be able to rent different sizes and brands to get a better feel for each. It was a JD 4105 the first time and plan to rent a Kubota L3800 next time, and JD 3-Series after that... The 4105 was honestly a little big for my needs. It pretty much laughed at whatever I tried to cut or dig/haul even with empty rear tires and just the cutter for ballast. A 3038e or L3901 with filled rears would probably be the ticket for me as I wouldn't mind paying the minimal charge to get a few extra ponies over the 3032e and L3301 to get the cutting or tilling done a little faster. Of course I say that having no clue what box blade work is like but that should just be limited to maintaining a driveway once in a while.
-I don't mind paying into the low 20s for a new or newer "3-Series" size machine with HST, FEL, 5' cutter, and box blade which from kicking tires at some local dealers seems very doable. R4 tires should be plenty and heck if not for the softer area near the pond tuff tires would probably even work. This is the first year I believe that JD and Kubota have the DPFs on their machines so another year for them to workout bugs (if there are any) before I buy isn't a bad thing in my mind. Those two by far have the best dealer network in the area with probably TYM being 3rd with possibly two dealers (if Cabelas actually does service) within 50 miles. I'd still rather not have the DPF so I may still look at pre 2016 machines. Although I'll admit I do "like" to buy things new and thus know I've cared for it from the start but I may have to just get over that. LOL!
/ Just starting on the tractor learning curve... #14
Well I'm a bit chuffed (that's a good thing :)) that you tried out a 4105. It's a 'bare bones' tractor, less expensive than a 3000 series, with the extra hp (40.5) that is great to have when needed.
With a bub on the way, you'll get 'more bang for your buck', which can be poured into needed implements... er, I mean your son.
2004 John Deere 310G 4x4 Loader Backhoe (A59228)
2004 John Deere...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2019 PETERBILT 579...
UNUSED TAYLOR-WAY 6' BOX BLADE (A62130)
UNUSED TAYLOR-WAY...
2014 Chevrolet Cruze Sedan (A61569)
2014 Chevrolet...
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
