JD 2010 help
/ JD 2010 help #1
Tejas
Hondo, Texas
NHL185, Kubota B7100
Hello folks, My neighbor has a John Deere tractor 2010 ( I think he said it is a 1963) and I am trying to help him work out several issues he is having with it.
Alternator isn't charging battery. He installed a new alternator and it has a new battery. I was hoping somebody might have a schematic / wiring diagram for this tractor...and or a photo of what is actually connected to the alternator (or in my case maybe, what is not connected.)
I found a sensor in the lower part of the block, near the alternator, that has no wire connected to it. I am assuming it is the oil pressure sensor and was hoping someone could confirm that.
The diesel tank appears to be leaking. I degreased the tractor and can tell there is a leak coming from up high, somewhere on or next to the tank. I would like to know if there happens to be a trouble spot on these models that I should be looking for?
What does it take to get the hood/cover off of this thing?!:confused:
Lastly, are there any sites you guys can recommend I can look to find replacement parts?
Thank you!
/ JD 2010 help #2
Pictures would help us understand what parts are on your tractor.
For example was the new alternator a GM one. That is the common one to replace more expensive OEM ones from the factory.
Dave M7040
/ JD 2010 help
I will take a picture and try to post it tomorrow, thanks!
/ JD 2010 help #4
No factory wiring schematic will be available for a 2010 with an alternator as they only came from factory with a generator. Oil pressure sender switch is parts key 37
/ JD 2010 help
Thanks JIM!! That surely helps. You wouldn't happen to have one of those schematics for the fuel tank/fuel system, would you? ;)
/ JD 2010 help #6
Tejas
What exactly type schematic do you need for fuel system. You can view it at JDparts.com.
/ JD 2010 help
IMG_0104.JPG-1.jpeg Ok, here is a pic of the alternator. I am assuming it is missing a ground? What size cable does it need to be?
There is a plug on the top of the alternator that is broken. Only one wire goes into it, in the 1 R terminal. The 2 F terminal is empty...should something be there?
The positive lug: there is a big cable, presumably going to the battery positive...where *should* the small wire be connected to?
Thanks for everyones assistance.
/ JD 2010 help
Tejas
Thanks for the link. I went to the site....is this tractor supposed to have a Positive ground?...will that be changed (backwards) if it has a newer alternator rather then the old generator?
Seems like all the gauges need replacing in the dash, can these be replaced with simple automotive style gauges?
/ JD 2010 help #9
2010 came from factory positive ground on elect system but most 12 volt alt are negative ground so my guess is 2010 has been changed to negative ground.
/ JD 2010 help #10
Tejas
Did you solve this tractor problem? or did the neighbor get it solved? just curious...
/ JD 2010 help
Yes I did, thanks. I don’t recall exactly what the problem was, but if I’m correct, I think the alternator wasn’t being excited.... causing the failure to charge.
