lots of questions about medium duty trucks.
/ lots of questions about medium duty trucks. #21
Any Allison AT545/MT643 will be OK, you can get a ReTran(r) remanufactured by Allison for LESS than a reman manual in most cases. Again, if the manual is not an EATON, RUN!
4MPG for a gasser is meaningless when you put on <4,000 miles year, you factor that diesel is 20% higher per gallon and can go bad faster than gasoline under some conditions. Infrequent use with low annual miles should tip the scales to gas. Remember, you can get a new or reman gas engine installed for less than a rebuild kit on a diesel.
My suggestion is to worry less about how many MILES are on the rig and worry more about what condition it is in. A CLEAN truck that was well maintained with 200K on it is a better bet than an average truck with 100k on it.
/ lots of questions about medium duty trucks. #22
Any Allison AT545/MT643 will be OK, you can get a ReTran(r) remanufactured by Allison for LESS than a reman manual in most cases. Again, if the manual is not an EATON, RUN! 4MPG for a gasser is meaningless when you put on <4,000 miles year, you factor that diesel is 20% higher per gallon and can go bad faster than gasoline under some conditions. Infrequent use with low annual miles should tip the scales to gas. Remember, you can get a new or reman gas engine installed for less than a rebuild kit on a diesel. My suggestion is to worry less about how many MILES are on the rig and worry more about what condition it is in. A CLEAN truck that was well maintained with 200K on it is a better bet than an average truck with 100k on it.
There you go. Good sound advise. A set of brakes is $2000, tires that much again. Gas is cheap compared to a truck needing work.
Chris
/ lots of questions about medium duty trucks. #23
/ lots of questions about medium duty trucks. #24
The big issue would be getting the air brakes and its been a while, but I do not remember a lot of gas trucks with air brakes.
/ lots of questions about medium duty trucks. #25
There are a few gas trucks with air brakes, I see them from time to time.
Aaron Z
/ lots of questions about medium duty trucks. #27
It would be a dam cheap gas motor to beat 1250 bucks for an inframe in a diesel.
https://dieselrebuildkits.com/k2/di...ternational-navistar-dt530-engine-rebuild-kit
Yea, I would NEVER suggest aftermarket kits installed by Kaputi garage as a valid solution to any engine rebuild needs.
Also, your parts costs do not include labor; when you factor in ~$3000 in overhaul labor plus injectors, turbo and HPOP compared to $1500 for R&I of a gas engine, you are worlds apart.
/ lots of questions about medium duty trucks. #28
You can get a genuine navistar engine rebuild kit for DT466 built before 9/93 About $1000.00, the newer one will cost more
Sent from my iPad using TractorByNet
/ lots of questions about medium duty trucks. #29
Even then you are not getting injectors, injection pump, turbo or oil pump for that money, nor the labor to do it.
/ lots of questions about medium duty trucks. #30
I really think you are looking at this the wrong way. The cost per mile of a diesel is much better than a gas motor. That's what it comes down to. Well that and pulling power.
/ lots of questions about medium duty trucks. #31
Not if you use it as most owners do, less than 3000 miles a year. Heck, we have 5 on my road of 12 houses and I bet most don't see 300 miles a year.
Chris
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
2013 NISSAN NV3500 CARGO VAN (A59905)
2013 NISSAN NV3500...
