lots of questions about medium duty trucks.
/ lots of questions about medium duty trucks. #21
Any Allison AT545/MT643 will be OK, you can get a ReTran(r) remanufactured by Allison for LESS than a reman manual in most cases. Again, if the manual is not an EATON, RUN!
4MPG for a gasser is meaningless when you put on <4,000 miles year, you factor that diesel is 20% higher per gallon and can go bad faster than gasoline under some conditions. Infrequent use with low annual miles should tip the scales to gas. Remember, you can get a new or reman gas engine installed for less than a rebuild kit on a diesel.
My suggestion is to worry less about how many MILES are on the rig and worry more about what condition it is in. A CLEAN truck that was well maintained with 200K on it is a better bet than an average truck with 100k on it.
/ lots of questions about medium duty trucks. #22
Any Allison AT545/MT643 will be OK, you can get a ReTran(r) remanufactured by Allison for LESS than a reman manual in most cases. Again, if the manual is not an EATON, RUN! 4MPG for a gasser is meaningless when you put on <4,000 miles year, you factor that diesel is 20% higher per gallon and can go bad faster than gasoline under some conditions. Infrequent use with low annual miles should tip the scales to gas. Remember, you can get a new or reman gas engine installed for less than a rebuild kit on a diesel. My suggestion is to worry less about how many MILES are on the rig and worry more about what condition it is in. A CLEAN truck that was well maintained with 200K on it is a better bet than an average truck with 100k on it.
There you go. Good sound advise. A set of brakes is $2000, tires that much again. Gas is cheap compared to a truck needing work.
Chris
/ lots of questions about medium duty trucks. #23
/ lots of questions about medium duty trucks. #24
The big issue would be getting the air brakes and its been a while, but I do not remember a lot of gas trucks with air brakes.
/ lots of questions about medium duty trucks. #25
There are a few gas trucks with air brakes, I see them from time to time.
Aaron Z
/ lots of questions about medium duty trucks. #27
It would be a dam cheap gas motor to beat 1250 bucks for an inframe in a diesel.
https://dieselrebuildkits.com/k2/di...ternational-navistar-dt530-engine-rebuild-kit
Yea, I would NEVER suggest aftermarket kits installed by Kaputi garage as a valid solution to any engine rebuild needs.
Also, your parts costs do not include labor; when you factor in ~$3000 in overhaul labor plus injectors, turbo and HPOP compared to $1500 for R&I of a gas engine, you are worlds apart.
/ lots of questions about medium duty trucks. #28
You can get a genuine navistar engine rebuild kit for DT466 built before 9/93 About $1000.00, the newer one will cost more
Sent from my iPad using TractorByNet
/ lots of questions about medium duty trucks. #29
Even then you are not getting injectors, injection pump, turbo or oil pump for that money, nor the labor to do it.
/ lots of questions about medium duty trucks. #30
I really think you are looking at this the wrong way. The cost per mile of a diesel is much better than a gas motor. That's what it comes down to. Well that and pulling power.
2014 FREIGHTLINER CASCADIA 6X2 MID ROOF SLEEPER TRUCK (A59908)
2014 FREIGHTLINER...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
207278 (A52708)
207278 (A52708)
20' DOUBLE AXLE INDUSTRIAL TRAILER (A59823)
20' DOUBLE AXLE...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
2022 Ram 2500 (A55973)
