Bottom plow in rocky soil
/ Bottom plow in rocky soil #1
sqdqo
Marquette Michigan
Massey Ferguson 492 w/Quicke Q750 loader
I dont have alot of farming experience and need to turn a heavy sod type field that has never been turned. The soil has a fair rock content. I have the option of either a three point bottom plow or a tow behind chisel. I think I would rather use the bottom plow but am afraid of damaging with rocks. I've used the chisel in other rocky locations and it rips the ground up but it makes quite a mess of things. Any opinions from anyone?
/ Bottom plow in rocky soil #2
You need a Kvernland moldboard plow;built for rocky country.Works very well for us.
/ Bottom plow in rocky soil #3
Sodbusting calls for a moldboard plow.
I have never seen a "tow behind" Chisel Plow, but presume it is a conservation type plow, like mounted Chisel Plows, designed to pull through crop residue, not turn sod.
There are rocks, then there are ROCKS. A moldboard plow can handle rocks without damage. Make sure the trip/shear function on the plow and Position Control on the tractor are working correctly. It is not difficult to stand a tractor vertically on end, pivoting around the 3-Pt linkage, should these safety features NOT be working, should the plow encounter an immovable object underground.
Adjusting and operating a plow, especially a plow larger than a two-bottom plow, is an intermediate level skill. Do you have someone with experience who can help you get started?
A 12" plow (measure from center of one plow beam, to center of next plow beam) will leave 12" waves in the field. To knock down the furrows, a Disc Harrow is used in succession to the plow.
WHAT IS YOUR OBJECT IN BREAKING THIS LAND? Crop? Pasture? Vhat?
PLOWS & PLOW ADJUSTMENT: http://www.tractorbynet.com/forums/...oard-plow-wisdom-farmwithjunk.html?highlight=
Picture #3 + #4 Cleaning and lubricating trip plow mechanism.
I am going to turn it into a food plot. Rocks vary in size from small stone to 100lb rocks.
/ Bottom plow in rocky soil #6
Plowing on sloping ground is really hairy.
For game food plots I would use a HEAVY Disc Harrow, one with 20" diameter pans or greater, spaced 9" apart, for soil prep, amend, sew seed, then roll in seed with a Cultipacker. Food Plot seed mixes are eager germinators. Much less hairy. That is enough. Lacking a Cultipacker, a drag can be used to cover seed lightly.
Most everyone owning a plow has a Disc Harrow, but not necessarily a Disc Harrow heavy enough to chop unbroken sod. A light Disc Harrow will not do the work.
A Disc Harrow with pans spaced 9" or more apart will roll over those small boulders. Disc Harrow does not have the considerable learning curve exacted by a three bottom plow.
It is too late to sow Fall food plots this year; wait until Spring 2016.
/ Bottom plow in rocky soil #7
I lived in heavy rock gravely glacial till soil for decades and tried it all. The moldboard plow worked, sure, but I had to pick rocks and disc, etc. What a nightmare and the ground was never fully flat. A chisel plow just pulls up rocks that you have to pick up. And we picked, year after year, ground that had been picked for 150 or more years. Rocks were my best crop.
What finally worked was a heavy duty Howard rototiller. I didn't go real deep and it did a perfect job while burying most of the rocks that showed up. The ground was flatter and no rocks to pick up. It worked for me and I would never disturb rocky ground. Just skim the surface. It worked perfect for my hayfields.
I know its to late to plant this year, I just wanted to get a jump on next spring if its worth it. We a have a 14' double row disc w/18" pans but it is not heavy enough to cut the sod on its own, I tried it.
It is too late to plant Fall food plots this year; wait until Spring 2016.
/ Bottom plow in rocky soil #9
A 10 lb rock will beat the ____ out of a rototiller. What would a 100 lb rock do. I would either plan on picking a lot of rock or leave it alone. Ed
/ Bottom plow in rocky soil #10
It's not that hard, and doing it now will save you time in the spring. Your first effort at it will look like you're a beginner, but we all have to start somewhere, and you ARE a beginner so jump in the pool and start swimming. It is important to have a working trip/shear system. Some older and inexpensive plows were essentially one piece units without that function; you can tell if your plow has it by looking for grease fittings, adjustment bolts, maybe springs. If you don't seem to have it be extra careful and go slower. Try to pick some rocks before you run the disc over it a few times. I've actually had suburbanites approach me to buy some of my rockpile, and they come in handy for the oddest reasons.
/ Bottom plow in rocky soil #11
Chisel plows are great for soil that has been worked up before but in your situation I think the 3pt triple bottom plow is your best bet. You have more than enough tractor to handle it. For heavy sod your best bet is to roll it over for weed control now. Plus if you run the plow deep you should expose all the major that you will ever face since a plow runs deeper than a tiller or disc ever will.
You got the right idea on plowing it under right now. The freeze/thaw cycles up in your neck of the woods will help break up the clumps. I have a plow and I barely ever use it anymore but when I have to turn fallow ground that has been worked the plow is the first tool I grab. After it's been worked once than the chisel plow is my go to item.
/ Bottom plow in rocky soil #12
No surprise. A Box Frame Disc Harrow with 18" pans has 35 pounds to 40 pounds pressure bearing on each pan. You need 50 pounds to 60 pounds pressure bearing on each pan to chop sod. Chopped sod is enough for food plots. Ground does not have to be tilled, like a field, to get pretty good food plot mix germination the first year, better germination the second year.
Spacing between pans on your disc is probably 7", increasing float. Good post-plow field smoother, not a cutter.
How sloped is land for potential food plot(s)?
Moldboard plowing now, then Harrowing in early Spring, would be ideal if you can manage it and erosion will not be a problem.
/ Bottom plow in rocky soil #13
When SIXDOGS posts, heed the words.
/ Bottom plow in rocky soil #14
You don't till 8" deep at 540 RPM and don't hit rocks 100% of the time. The tiller bounces off the rocks if you don't go too deep and take it easy. It leaves the ground fairly smooth and a nice seedbed from the get-go. I did maybe 500 acres this way and it worked the best. We picked untold tons of rocks and I spent hours disking and leveling and smoothing. What a waste of time when the tiller works.
The plow and disc method in sod will require multiple passes, leave chunks of sod and holes here and there. It will need to be picked of rocks, disked and picked again and then smoothed and picked again. The tiller saved me enormous time and effort
That's my two cents from doing it and maintaining hayfields.
EDIT--on the tiller and rocks, I once moved my 500 ft driveway by rototilling it (yup, I did) and bucketing the gravel to the new driveway. I had to till a couple times because there were some pretty big rocks in it. I put the dirt where the gravel was and a day later you would never know what I did.
Even these days I do heavy duty tiller work and till all kinds of obstacles from smaller stumps and bricks to rocks and drain tiles. I don't seek this stuff out and I take it easy but I don't get off the tractor. I have had fields of rocks that people wanted to spend days picking for lawn prep and I rototilled it, packed and seeded before it rained and you can't find a rock. The tiller buries them after you figure out speed, depth and technique. I do it all the time.
I love the moldboard plow but it's use is really limited.
/ Bottom plow in rocky soil #15
I like sixdogs tiller suggestion. I've tilled a few construction sites full of buried debris, slow, shallow and about one third throttle.
Also, if you have access to a disc-plow, that is pretty much what they were made for.
/ Bottom plow in rocky soil #16
