Hello from CT!
/ Hello from CT! #1
Rustyferrious
Ivoryton, CT
Kubota BX25D
Or maybe more appropriately, "Howdy Y'all".
Took delivery of a Kubota BX25D in August. Been reading up on various aspects of tractorology on the site. Picked up a lot of good info. Liked what I saw so decided to join up. Some photos attached.
Took on a big project this past summer. Wife said our yard looked like crud (not her exact words), so we embarked on a back-breaking, pick & shovel, wheelbarrow carting adventure. Of course, by "we", I mean I did the picking, shoveling, carting and back tuning. She earned the bonus to pay for it all. It was a good partnership. Project involved removing an existing blue-stone walk, a 100 or more Belgian block edgers, a brick paver grille pad, lots of top, sub soil & sod. Countless trips made with the wheelbarrow carting the materials to various locations around the property. I ain't no spring chicken either. After clearing the site, I installed a new 35 x 20 brick paver patio with retaining walls, new wood steps up to the deck, new stone steps up to the garage entry, an outdoor shower, three raised bed garden boxes, a picket fence, pergola gate, tractor gate, cobblestone walk, crashed stone parking area and a hot tub. Then, the combination of my steady progress, along with my moans and groans, finally had the desired effect - a brand-spanking new orange BX - with accessories! Along with the FEL and BH with thumb, the package included a set of forks and frame, a post hole auger with 9" bit and a hydraulic front blade. I also added a 60" landscape rake, a BXpanded Piranha Blade for the bucket and an Under-Armor plate for the belly. Currently building a road to the rear of the property, which involves a 40' ramp that runs alongside the storage barn, up over some ledge I'm cutting through and back down the other side to a relatively flat area where I want put another storage building and equipment/toy corral. last photo shows the rock fragments I broke up and excavated for the ramp retaining wall. Using feathers and shims to break up the boulders and ledge, then used the thumb on the BH to lift them out. The open framed structure is part of the chicken run attached to the back of the barn. I had to build it over a huge granite outcropping that runs across the middle of the property.
/ Hello from CT! #3
Like your little dog and I guess those are chickens?
/ Hello from CT! #4
Welcome to TBN, fellow nutmegger Rustyferrious!
Looks like you wasted no time putting your new machine to work.
Congratulations and keep us updated as you take on new projects.
I haven't used a set of shims & feathers in many years and kind of miss the experience.
It didn't take me long to figure out using a looong tube to blow the rock dust out of the bottom of the holes would keep the grit off my teeth & out of my eyes.
-Jim
/ Hello from CT!
Thanks for the welcome note. We have two pembroke corgis. Cousins. Magic is the tri fluffy in the photo. Dragon is the red& white. Dragon is an excellent chicken herder. Magic, not so much. Magic put himself in charge of security. He will raise a ruckus at the slightest provocation, real or imagined.
23 or 24 laying chickens (they come and go) of various types, including a few of our own concocktion, so to speak.
/ Hello from CT!
-Jim
Hey Jim, Thanks for the welcome note. Yep, loong blow tube is a must for this kind of work!
/ Hello from CT! #7
Makin' lilluns outa bigguns! Was this so you could run some fence below ground level to keep the coons, foxes, coyotes and fisher cats from disrupting your lay-away plans?
/ Hello from CT! #8
Welcome to the forum.
Congrats on the new machine and all of your progress so far! :thumbsup:
/ Hello from CT! #9
Nice tractor, and good progress on the yard project. The good news about living in CT is you have access to all the rocks you will ever need in 10 lifetimes!
/ Hello from CT!
I didn't bury the wire around the day run, I ran it 18" down around the coop itself. With the dogs around nothing bothers the girls during the day. But at night I wanted high security, as you're well aware, we have all kinds of predators around here. The coop is the small building to the left. It is connected to the day run via the "chunnel" (chicken tunnel). The barn is where the 'Bota lives, along with the other yard gear and boat stuff. Up until now we kept our little runabout in the barn, but there's not enough room for the boat and the bota so the boat is wintering outside under a cover. The rock that I posted was on the other side of the barn, where I need to put in the retaining wall for the ramp. Had to break it up so I can lay the wall block right up to the ledge outcropping.
/ Hello from CT!
You got that right! We're originally from NW PA. moved to CT in 2000. Back in PA I could dig 100 holes and not find a single rock larger than a baseball. In CT, I pull out a half dozen melon size rocks from one post hole. I'm seriously wondering how the PHD will work for me. I bought extra shear pins. Farming CT must have been a daunting undertaking. There's more rocks than dirt!
2023 Kubota Z252KH-54 Zero Turn Mower (A63118)
2023 Kubota...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A62131)
UNUSED RAYTREE...
BUNDLE OF APRROX (25) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
Mini rock grapples (A61567)
Mini rock grapples...
2023 John Deere Z950R Zero Turn (A63116)
2023 John Deere...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
