Let's Talk Air Filters........
/ Let's Talk Air Filters........ #1
gltrap54
Topeka,KS
B3200 Kubota
Just replaced both inner & outer air filters on my B3200 & with the cost approaching $100 bucks. Manual recommends changing them yearly........ I put about 50 hours a year on my tractor & keep the outer filter & evacuator valve clean...... While I recognize the importance of an air filter's function, could I safely go two years between changes?
/ Let's Talk Air Filters........ #2
I blow mine out and maybe replace if beyond cleaning.A lot depends on operating conditions also.50 hours a year maybe change every three years.
/ Let's Talk Air Filters........ #3
Agreed, If not in a dusty environment you can expect greater lifespan.
/ Let's Talk Air Filters........ #4
I'm over 2 years and almost 200 hours on my factory air filters, with moderate dust while brush hogging. I air hose out the radiator daily, and the air filters about every 15-30 hours. I think I will replace the outter air filter soon. I would go by hours of use, not years of age.
/ Let's Talk Air Filters........ #5
I agree that your filter is probably fine for years, yet. But... If your tractor is still under warranty, I would recommend doing all the maintenance & servicing "by the book". Just to keep your warranted butt covered.
I check my air filter regularly & the only time I found it dirty was when levelling ground this summer during a loooong dry spell. Being under warranty, I change it religiously in accordance with the maintenance schedule.
I'm lucky that Kioti uses a common Donaldson air filter on my tractor. $32.00 at the local NAPA.
It's the hydraulic filters that leave me with a limp wallet!
/ Let's Talk Air Filters........ #6
If the filters don't look clean after blowing them out (by that, we mean from the inside towards the outside) then replace them. No need to waste money if nothing is to be gained. Unlike fluid filters, it is easy to visually inspect your air filters.
/ Let's Talk Air Filters........ #7
After blowing the filter clean, stick a bright light inside the filter. If you can see the light through the filter, it is good enough to use.
Words to live by......... Everyone seems to be in agreement here...... Soooo, I'll stop throwing my money away..... :drink:
/ Let's Talk Air Filters........ #9
The inner filter doesn't need changing in most cases unless the outer filter has failed. I change my outer filters once a year but they need it. I don't go to the dealer though. Try looking at a local truck parts place like TruckPro. I get Donaldson filters @ about 25% dealer price.
/ Let's Talk Air Filters........ #10
I do a little different. I use a shop vacuum with a small nozzle on the outside of the filter. I think it is easier and less likely to blow a hole thru it. In other words, high volume low pressure air. Then I hold the filter up to the sun and look from the inside to the outside at the sun. If I see a bright light hole, it goes in the trash, otherwise if it appears clean and no holes, it goes back on the tractor.
Yup after reading posts in this thread, the $50 inner filter went back to the dealer......... I did install the outer filter & probably didn't need to....
I'll have to do a search for a Donaldson dealer............ :cheerful:
/ Let's Talk Air Filters........ #12
Just so you know, Donaldson makes filters for nearly everybody. Most likely the factory filters you run now are made by Donaldson.
/ Let's Talk Air Filters........ #13
I will guarantee the original one in my Kioti was.. said so right on it.
/ Let's Talk Air Filters........ #15
$50 for an inner filter ??.
I'd hate to know what the outer filter cost.
/ Let's Talk Air Filters........ #16
Your local auto parts store can get or cross the Donaldson number easily. My factory outter filter has Donaldson printed on it, I keep forgetting to write that number down to check on price and availability.
/ Let's Talk Air Filters........ #17
If truth be known Donaldson probably makes them anyway
/ Let's Talk Air Filters........ #18
Another source: WIX, go to their excellent web site to get the numbers and then use your Amazon prime to get delivered free and quick,
Kubota V1505E3D24 Engine
51344
33830
49410
WA10015
51361
Rooster
/ Let's Talk Air Filters........ #19
Never attempt to clean an inner air filter. They are supposed to be a safety guard in case the outer fails or leaks. I never even remove mine unless I am replacing it which isn't very often. Hundreds of hours.
Outer air filters can be blown out a lot. We have a tracked skid steer that has been converted into a drilling rig and it drills holes using compressed air. Basically operates in a cloud of dust so thick sometimes you can't even see the machine. When in use it does this 12 hrs a day 7 day a week. We blow the air filter out daily and and maybe replace it after a few hundred hours. I have watched many dozer operators PM their machines and they blow their filters out daily and it is crazy how much dirt comes out. Maybe they change them back in the shop but I have never seen them change one on a job and sometimes they are there for weeks.
A typical homeowner tractor probably only needs an air filter every couple of years.
/ Let's Talk Air Filters........ #20
If you want your diesel engine to live you must feed it absolutely clean air. I use a shop vacuum to clean the outer filter every day when working in dusty conditions. Since the Kioti did not come with an inner filter I added it. it does not take much grit to dust an engine.
2020 John Deere R4044 Sprayer (A63111)
2020 John Deere...
2009 Blue Bird All American/ All Canadian School Bus (A61573)
2009 Blue Bird All...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2008 Ford F-250...
2025 Fabrique 12' x 6' Dump Trailer (A62613)
2025 Fabrique 12'...
Caterpillar 12H/140H/160H Motor Grader Parts and Service Manuals (A63117)
Caterpillar...
Reichardts Green Fit Kit for C Series RoGator (A63117)
Reichardts Green...
