LS backhoe questions. please post pics of subframe mount.
/ LS backhoe questions. please post pics of subframe mount.
Paint Department
... switching to a stealth fighter motif. Na, it's just primer.
Paint Department
All better now ...
Re: Paint Department
Looking good
Thanks! It's Rustoleum Sail Blue so it isn't going to match and I'm OK with that for now. My main concern was to protect where I welded and grinded the reinforcing plate and the rest of the mount was dinged up some too so I wanted to nip any rusting. Lord willing if I ever get my road and pole barn built I'll have better facilities than I do now (... working in the driveway in my back yard under a canopy), I'll redo it with the proper matching paint.
Tonight was fun. I bolted the sub frame back up so I could finish tacking the finishing pieces on (after I cut them out) and I guess it heat warped just a hair when I took it off to do the root welds ... was fun getting the bolt holes to line back up. That always happens to me no matter how hard I try.
Actually, I think the biggest problem was aligning the holes of 3 stacked parts ... my mount, the 3pt. anti-sway bar bracket, FEL rear rails and the ROPS/transaxle (that's 5 things actually! :) ). Hard to see up in the hole to make sure everything is lined up.
Next I'm going to cut a bunch of triangle gusset plates to add strength to some key areas and fabricate a new draw bar mount (I don't want to give up my draw bar like with the factory mount ... I want it all ;) ) and of course last but not least, the 4 point cradle.
Since it isn't fun to take this thing on/off (it's getting pretty heavy) I'm going to tack up as much as I can this time so hopefully I'll only have to take it off again to do the final welding (still haven't done the 7018 yet) and maybe one more time for cleanup/paint.
I found a new use for my creeper. I put the subframe on it and roll it up under the tractor and use two small floor jacks to lift the subframe in place. I also found a new use for tree felling wedges. They were good to shim up (heavy) stuff while I tack welded. I'm learning all kinds of things on this project.
Test Fit
Tonight I test fit the new drawbar mount that bolts to the 6 holes around the PTO. I could of hacked up the original mount but I wanted to be able to put it all back original if I ever wanted or needed to. Plus the new one is made out of 1/2" so it's about an 1/8" thicker than the original.
The bottom of the plate hangs down almost 3" because I will have another 1/2" plate welded at 90 degrees (horizontal) that runs back to the cross member between the ROPS mount to help reinforce it. I plunge cut the drawbar hole (my first plunge cut!) and cut out the parts to make the new drawbar mount.
I stuck the drawbar in the hole just to make sure it had enough clearance to fit through the 'hidey hole' I made for it.
This one shows how the plate comes down level to the cross member (which will have a horizontal plate running back to the cross member and triangle guessets):
/ LS backhoe questions. please post pics of subframe mount. #48
Re: Test Fit
Pretty Cool! I envy you guys that can do this kind of stuff and actually have it work.
Re: Test Fit
You could do it if you put your mind to it. I never had any formal training in any of this ... well I did have 1yr. of high school shop class but that was forever ago.
Mock-Up Continues
... twas the night of 1/8" mistakes :(. Nothing major, just hits to my pride. The wife's 'honey do' list was quite large so I didn't get the time I wanted to work on the project for the past few days. Working in the dark and trying to hurry doesn't go together very well.
I tack welded the parts I cut out a few days ago. Here is the underside of the new drawbar mount around the PTO where it ties into the cross member (you can see where my one of my triangle gussets is an 1/8" oversize):
I started tacking on the actual drawbar mounts and screwed up and got it 1/8" off center (still need to cut pin holes in the top/bottom parts):
Kind of a side view shot:
And here you can see why I lost an inch of clearance ... big rigid hydraulic line was in the way:
Time to do a jig
This chicken scratch is an attempt to make my template for the 4 point cradle. Scissor skills from kindergarden finally came in handy. Used a USPS priority box (thanks Uncle Sam) and some duct tape to work out a shape that would work.
Next I plan to cut out a plywood jig I can drag my plasma torch around for the main shape.
The right angle part (yea, looks kind of like Texas) will sit on the cross member between the ROPS mounts shown in previous pictures.
Rain coming so who knows how much I'll be able to get done this weekend.
After the rain stopped
Haven't been able to post an update in a while because it's kind of hard to use a plasma cutter in a boat! Well, we didn't get rain like SC did but I did miss over a week of getting anything done.
So after my hillbilly engineering in the previous post (who needs G Code? Well, I would like it!) I cut my template out with a jig saw and then used the plasma to cut four of these parts (picture in previous post) out. That went pretty well except I ended up running my compressor quite a bit (more than usual) and when it heats the lines then you get condensation. I had a small dryer just before the plasma and it got saturated while cutting the parts out and I got about 1/8" of water in my separator that I emptied about three times!
So I realized I needed to do something different so I bought the Harbor Freight dryer (69923). I read the reviews and saw where people complained about the little plastic service indicator (a orange thing that pops up when the filter gets too much of a restriction and needs changed/cleaned) but didn't think much of it. I got the thing for $40 so I thought that was pretty good compared to others I had seen and a lot of other stores don't even carry them anymore ... they show up on their web site but when you look real close it's not available in stores - available online only - ship to home.
I rigged up quick connect fittings because I have no place to mount it so I just want to fix it up for temporary use. I hook it up and go to try it and ... yup, the clear plastic service indicator thing is blowing air big time ... so the entire rest of the evening was spent screwing with that. :( To make a long story short, I needed to ditch that service indicator and plug it. I determined the threads were M16x1 which is an odd thread and none of the local suppliers had it. Sure, you could order a plug on the Internet but I need to get busy now!
I finally give up and just filled the cavity up with two part epoxy which turned out to work very well and not leak at all ... so now I'm in business:
After cutting out the four 1/2" plate parts, I was going to use my grinder to make a 45 along the edges because I plan to stack two of these parts together to get the thickness to 1" and I wanted a nice 'V' grove in the middle to fill in with weld to get better penetration/strength. I was kind of dreading doing this because I knew it was going to suck and take forever ... that's when I had an epiphany! I thought to myself 'hey, I could use the plasma to put a 45 on the edge'. I tried it out on one of the parts and boy, that's why faster than using a grinder! I was rolling along having a good time then I hear POP and my torch lost air and shut off. See anything wrong with this picture?
The two bodies are standalone units and they are held together with a ramp type clamp on each side that draws the bodies toward each other and compresses a rubber O-ring on each side of the mounting bracket in the middle. The screw backed out from the vibration of the compressor and the seal pooched out and blew all my pressure. It was easy to fix but looked pretty freaky.
I made it through three parts putting the 45 on the edge and then my dryer started getting used up. I didn't get any moisture in the plasma separator so it was doing it's job but I decided to change out the desiccant (I have a gallon more on the way from Amazon):
Hey buddy, want a dime bag of pink stuff?
This job made me realize I need a BIG compressor and one of those fancy refrigerated air dryers but hey are $$$$!
Here is one of the parts after I put the 45 around the edge:
Now I have to cut out the cradle area for the four pins to sit in and clean them up and weld them together. I plan to cut some holes on one side so I can plunge weld them too so they get some strength from the more than just the edge.
HF Bling!
Thought I'd show of my new HF bling:
I used it to tack my two parts together so I could then do a root weld without (hopefully) warping it. A friend put me onto this table when it first came out and told me how it was a knock off of a much more expensive table. I posted some details about it in the 'HF tools that don't suck thread' as I put it together http://www.tractorbynet.com/forums/...-tools-dont-suck-post4261730.html#post4261730
Here I'm filling in the grand canyon I made with the plasma so I could get some good welds/surface area. Once I fill that gash up this baby should be pretty stout!
I like how I can tilt the table and cheat by not having to weld out of position:
My only regret is I didn't get one sooner. I got it for a pretty smoking price and liked it so much that I really did go back to the store and bought another one (the coupon has a limit of 7 ... so you can give them as Christmas gifts ... stocking stuffers!)
/ LS backhoe questions. please post pics of subframe mount. #54
Re: HF Bling!
[snip]
Boy, is my wife going to be thrilled with hers! :)
/ LS backhoe questions. please post pics of subframe mount. #55
Re: HF Bling!
Bought one of those for the woman this weekend. Great price with the coupon. She really loves a bargin
Re: HF Bling!
I'm sure it will go great with her shoes! :)
4pt. Cradle tacked on
Today I fired up the backhoe and used the hydraulics to get it off the shipping crate/pallet:
Next I got my 4 point cradle brackets tacked on:
Next I'm going to cut out two big parts to go from the backhoe to the cradle pin holders and install the pins. After that it should be some bracing, final welding then paint!
Factory Backhoe height?
Could someone with the factory R3039 backhoe comment on the height off the ground at the two points I marked in red?
These last parts I'm going to cut out tomorrow will determine the mounting height of the backhoe. I don't want to get it too high or too low.
Thanks!
/ LS backhoe questions. please post pics of subframe mount. #59
Re: Factory Backhoe height?
Don't have an LS, but holdin' a thumb up and looking, it seems just fine. More clearance (departure angle), is more better for maneuvering, traversing gullies, and loading on a trailer - - while taking little away from max digging depth. As long as the stabilizers have adequate spread and remaining lift, it'd say good enough.
Wish I had that much clearance on my cab, where the hoe has an extension so there's room for an outside seat.
All major parts cut!
More plasma action tonight with my trusty PP50:
Cut out the side mounts for the backhoe. Next I have to locate the pins and weld them on. Here's one of the sides:
Pretty much used up all my plate I bought ... still a little skin on the bones so hopefully I have enough scrap left to make the final small parts:
2012 Freightliner Cascadia (A61307)
2012 Freightliner...
2016 16ft. C and S Lawhon 2.5 Ton Pipe Top T/A Utility Trailer (A60352)
2016 16ft. C and S...
2017 PETRBILT 389 6X4  T/A SLEEPER TRUCK TRACTOR (A59908)
2017 PETRBILT 389...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
