bucket size
/ bucket size
There is no doubt the consensus has reached a verdict and everybody loves their grapples. If I had to buy a new 4n1, I wouldn't, but for 1200, I cant resist and worst case is that I just resell it, but I don't plan on taking it off the tractor. If I had any plans on moving some brush or doing any clearing, I would consider a grapple right now, but I don't see myself using it anytime soon and the fact that I need a tooth bar just makes the 4n1 a little sweeter of a deal. I only saw one grapple bucket for $1500 and it was only a 50" and claimed to be rated up to 35hp tractor. All the others I saw were $2000. Please advise if I am missing something. I only looked on everything attachments as I assumed that is who you were referring to.
/ bucket size #22
I got a new 48 incher, they were asking $895 for. I like the narrow size as I can reach between stuff to grab stuff. Remember it has no sides, so on a grapple width isn't as important.. I can, and have, picked up a 15 foot log with mine.
Look around there are plenty less expensive ones out there! I found mine on Craigs list here in South Carolina.
/ bucket size #23
Bottom line, you will be the one using it. So, go get it:thumbsup:
/ bucket size #24
How about these examples to show that a grapple can manage big
single rocks and tree trunks. As far as standing 4" tree trunks, just knock'em over, stick the grapple
underneath and pop'em out. Which of these tasks can be done with a 4n1???
If you reread what I wrote, you will see that I said "2-jaw grapple bkt". Yours is one jaw, which allows
you to lift at capacity from the center. Here is a 2-jaw bkt add-on.
GP
In clearing small trees with a 4n1, I open the bkt next to the sapling and lower it while turning the
wheel. This pushes the sapling over and then you close the clamshell on the trunk. Lift, curl, push,
and/or pull and it is out. No need to dig it up.
/ bucket size
I haven't had any trouble mounting generic skid steer implements to my DK40se. The standard DK40se bucket however is a narrower mount than most skidsteers (go figure) so it might be hard to mount the Kioti bucket onto a skid steer.
Well, to much my disappointment, the 4n1 didn't hook up as can be seen from the pictures. The good news is that the cylinders are working just fine and there are no apparent leaks. I hope to take Friday off and get the torch out to widen the slots for the pins to go into. I'm assuming this is fairly straightforward, just cut out the slots so the pins will fit... Anybody have any thoughts on things I need to take into consideration or any pointers that might make this adjustment go smoother.
The bucket hoses will need to be rerouted and possibly shortened, they are coming out from the bottom left side of the bucket and I will need to run them from the top to my center post.
/ bucket size #26
Odd that the pins are wider spaced. My experience has been that the Kioti QA is narrower than usual.
Agree that torch or plasma cutter would be the way to fix it.
/ bucket size
Do you have a picture of your hose setup? Are you using a fixed mount on your loader center post? I'm just trying to get some ideas on what might work best.
/ bucket size #28
I'll try to find a photo to post later. My tractor hydraulics terminate in a rigid mount on the torque tube. Quick connects go from there to the grapple lines. I use a bungee cord to keep slack out of harms way but am thinking of mounting a torsion spring stand off like EA uses as it would be more effective and look about 1000% better.
/ bucket size #29
Hmm, that is odd, I would have thought all QAs made to fit SS would be really close to the same, but I looked at a few of my QA attachements this morning and some have two slots and some three, but none had one big slot on the lower attachment point. Troch and grind will fixer up.
/ bucket size #30
I understand the John Deere ones are narrower. I've never seen one , but that is the rumor. :confused:
/ bucket size #31
Here is a photo that shows the hoses connecting on the torque tube cover. There is a welded bulkhead that the tractor side hoses are mounted to. The grapple side hoses are usually loosely contained by a bungee but I don't see it in this photo. Also, this photo was apparently taken before I put a protective sleeve over the grapple lines.
/ bucket size #32
Sorry, having trouble posting photos today. The grapple side hoses are usually loosely contained by a bungee which can be seen if you look closely under the torque tube of the second photo(there is a zip tie on the protective sheath the bungee hooks into).
/ bucket size #33
Well, to much my disappointment, the 4n1 didn't hook up as can be seen from the pictures. The good news is that the cylinders are working just fine and there are no apparent leaks. I hope to take Friday off and get the torch out to widen the slots for the pins to go into. I'm assuming this is fairly straightforward, just cut out the slots so the pins will fit... Anybody have any thoughts on things I need to take into consideration or any pointers that might make this adjustment go smoother. -------
Yep, just cut the slots wider.
2013 Ford Escape AWD SUV (A61574)
2013 Ford Escape...
Caterpillar 980G Wheel Loader Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar 980G...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
2012 John Deere 328D Compact Wheel Loader Skid Steer (A61572)
2012 John Deere...
JCB 3TS-8T Compact Track Loader Skid Steer (A61572)
JCB 3TS-8T Compact...
