Rotating pickup tires
/ Rotating pickup tires #1
Wolfy
a small town
a fleet of them
How often do you rotate your tires, if at all? Pickups and 6 wheel mason dumps. There are a lot of "right answers" at work.
/ Rotating pickup tires #2
I try to get the E350 van tires rotated once a year. More to check the balance of them than rotation. Due to the van axle layout the front and rear has different track with which I think affects the tire wear.
That is a good point I had not thought of...the front tires of the 6 wheel dumps fall somewhere between the middle of the rear duals.
/ Rotating pickup tires #4
I measure tread depth across the face of the tread and compare front to back often. When I start to see inconsistencies, I rotate. I have to rotate the tires on my wife's pickup more often than on mine. She can beat about anyone off the line and the tires show it!
/ Rotating pickup tires #5
My Nissan 4x4 gets rotation every oil change - 4K miles, my F250 SD 4x4 every 5K miles. I'm a professional mechanic and if I've got it on the lift for an oil change I might as well do the tires too. I usually go ahead and stick them on the balancer while off too if I'm not rushed. Belts constantly move in tires and change the balance - yes, even the expensive Michelins too ...
/ Rotating pickup tires #6
I rotate the tires on my 4x4 every 6 months. Spare to right rear, right rear to right front and right front to spare. Left side is just front to back.
/ Rotating pickup tires #7
When I start to notice the fronts wearing on the sides.
/ Rotating pickup tires #8
Don't know what a mason dump is, but my dualies are 7,000 miles. At 10,000 the fronts start showing abnormal wear. At 7000 they wear consistently across until tires are shot.
/ Rotating pickup tires #9
I rotate mine every other oil change, or somewhere around 10k miles.
A mason dump is a small 6 wheel, 1 ton rated dump truck. Around me if you say "dump truck", most people assume you mean a 10 wheel dump.
/ Rotating pickup tires #11
I get my 2 vehicles checked for alignment, tires re-balanced & rotated every fall.
/ Rotating pickup tires #12
When I buy new tires, the old ones to the recycle pile .
Sent from my iPad using TractorByNet
/ Rotating pickup tires #13
I replace my tires every two years regardless of the mileage on them. Off they go and into the back shed well out of direct sunlight. My theory is that when I retire I will not be able to afford new tires but I can run on the old ones for an extra 2-3 years each set. I have 4 complete (5 tire) sets, so right now if I was to retire I can run on two year old tires for 8-12 years plus the set I currently have on.
/ Rotating pickup tires #14
In five years, your two year old set of tires behind the shed will be seven years old. Time does not stop for aging on tires.
/ Rotating pickup tires #15
into the back shed well out of direct sunlight I guess you missed the part where I said 'INTO' and well out of direct sunlight.
How do we know for sure how old the tires are when we buy them to begin with?
Do they have a date of birth/manufacture on them?
/ Rotating pickup tires #19
I rotate mine when I install the winter tires at the end of September. Here the winter tires stay on from 1st October through to end of April - legal requirement here. I have a set of spare rims which have the tires mounted on. I make sure the tires are marked as to where I want to put them next time around.
/ Rotating pickup tires #20
My work truck (Ram 1500) gets rotated every other oil change, so every 10,000 miles, almost exactly every other month. I Just (25 minutes ago) replaced the original tires, got 15 months/83,800 miles out of the Goodyear Wrangler street tread.
Edit: replaced with 4 new Falken Wildpeak H/T 265/70r17; install, balance, disposal, tax, out the door $630.94
Industrias America 435 (A64119)
Industrias America...
(2) UNUSED 12-16.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 12-16.5...
Grapple Rake Mini Excavator Attachment (A61572)
Grapple Rake Mini...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
Year: 2016 Make: Mercedes-Benz Model: SLK-Class Vehicle Type: Passenger Car Mileage: 116,700 Plate: (A61574)
Year: 2016 Make...
