Annual Chimney Cleaning
/ Annual Chimney Cleaning #1
Dr_Zinj
Barrington, NH
Bobcat CT230
Tractor and FEL make getting up and down from the roof a lot easier, and provide me a more stable work area holding the ladder in place. And yes, there's a 4x4 wedged under the FEL so it doesn't come down on me or collapse under me if the pressure leaks down. I tested it and it works great!
/ Annual Chimney Cleaning #2
If you were in the south, I would call it a hi tech redneck ladder, but since you're from up north I'll just call it yankee ingenuity lol. Good job, and I see nothing wrong with it. Can't tell in the pic's, but maybe next time you chock the wheels on the tractor too??
No need to chock the wheels, I just drop the backblade and it ain't going nowhere.
/ Annual Chimney Cleaning #4
I would not do that at all. It is easy to make a J shaped piece of iron to hook over the ridge of the roof and on to two rungs of a ladder to hold a section of ladder instead of rigging something and hurting your self. Ed
/ Annual Chimney Cleaning #6
Dr Zinj
If you Take a piece of 1" x 1/4 iron bar and shape it like a J. Bolt a piece of angle to the end of it to hook on the 2nd rung of your ladder and use a muffler clamp to bolt it to your 1st rung you will have a roof hook. Add a piece of angle to the end so it won't dig into your roof and you are good to go. You can figure size by your ladder. Ed
/ Annual Chimney Cleaning #7
Nice setup. Looks like it works like a charm.
Couple of tons of tractor and a 1000# capacity loader to simply hold a ladder and people still think its unsafe and would rather rely on some 1/4" barstock and a muffler clamp jerry-rigged onto the ladder and hooked on the roof......
I like the tractor better IMO.
I got it easy when it comes to cleaning my chimney though. Nice low 4/12 shingle roof with an old 3-legged tv antenna tower at the gable peak to climb. No ladder needed and easy walking on the roof.
/ Annual Chimney Cleaning #8
Dr Zinj
Or just go the the hardware store and buy a ladder hook for under $20 that is designed to hold a ladder over the roof peak.
Ed: I considered that as a need to hold and stabilize the ladder lying on the roof. However, I still need something to lift the ladder up there (I'm not Superman or the Hulk); and the FEL fits that bill perfectly, at least for the lower roof. Once I'd done that, I realized that putting a hook on the ladder was superfluous. Parking the tractor with the blade down and the brakes engaged and locked, and then blocking the lift provides just as much safety as the hook would. After all, use of the FEL as a lifting jack is standard procedure for all kinds of things like pulling engines and transmissions, or even holding a work platform, as long as jack stands or similar devices are used to prevent unexpected drops.
On the other hand, the FEL doesn't go high enough to do anything with the upper roof, so there the ladder hooks would work. Problem is, with a hook, it tends to tear up the shingles as it slide up and over them. A pair of rollers bolted to a hook and angled in such a way that it rolls up the roof, but the roller don't touch it after it slips over the ridge would work nicely. Of course if you have a scissor lift and roof jacks, then you don't need to worry about it. However, how many of us are so flush with cash we can go right out and buy, or even rent that sort of thing all the time?
/ Annual Chimney Cleaning #10
Why not just get the proper sized ladder and lean it against the side of the chimney? I keep a 40 footer around just for such occaisions if needed. Spent most of my life on ladders... never once put one in a FEL! Get the right tool for the job my dad always told me... bless his soul.
/ Annual Chimney Cleaning #11
Also done that Dr_Zinj,even cleaning snow off on roof ridge...felt safer no ladders sliping.
/ Annual Chimney Cleaning #12
I spend a fair amount of time on a ladder.
I feel safer working out of the FEL when I can. Or even using a shorter ladder in the fel as opposed to a longer (flimsier) ladder.
/ Annual Chimney Cleaning #13
Invest in better ladders!:thumbsup:
/ Annual Chimney Cleaning #14
Why? Even a lower quality 8' ladder working out of an 8' bucket is going to be more rigid than a top of the line 16' ladder. And there is a lot less risk of the bottom slipping out.
To each his own. But IMO, there is nothing wrong with working out of the loader, or out of a properly done loader/ladder setup.
/ Annual Chimney Cleaning #15
Difference of opinion I guess.. And there is no "proper" loader/ladder set up in my opinion, I think OSHA agrees. Not that I really pay much attention to OSHA!:laughing:
/ Annual Chimney Cleaning #16
According to osha...yea
But in reality, it can be done right and result in a very stable and safe work area. Sometimes safer than just a single larger ladder IMO
/ Annual Chimney Cleaning #17
Each to their own, you wouldn't catch me on a rig like that.
When I bought my present house I had the stove installer put up an external stainless steel chimney. Now all I need to do is remove the bottom cap and clean it standing with both feet on the ground, getting too old to balance at the peak of a steep roof with a chimney brush.
/ Annual Chimney Cleaning #18
... getting too old to balance at the peak of a steep roof with a chimney brush.
The professionals around here clean chimney's from the bottom. I suppose that works best with a fireplace and not a stove? Or is that otherwise not the best practice?
Terry
/ Annual Chimney Cleaning #19
Just rotate the ladder over so the hooks aren't pointed down and it goes up the roof exactly like a ladder that doesn't have hooks.
Having the ladder extended 3-5 feet past the roof like in the picture makes it possible to use that extension to catch yourself if you slip, this could then cause the other end to pop out of the bucket and down the roof you go sliding with your ladder.
/ Annual Chimney Cleaning #20
As I mentioned in my previous post, my chimney is an exterior SS and can be cleaned from the bottom. At my previous house it was possible to get the brush and rods up thru the cleanout door in the basement. Might be kind of messy if the only access is inside the house though.
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
2009 MAC 35ft. 75yd. Tri-Axle Aluminum End Dump Trailer (A64556)
2009 MAC 35ft...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2018 Ford F-150...
2018 FREIGHTLINER CASCADIA 125 T-A SLEEPER TRACTOR' (A67147)
2018 FREIGHTLINER...
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
SURE FIRE 5.3GPM LIQUID FERTILIZER UNIT TOWER (A64278)
SURE FIRE 5.3GPM...
