FEL rebuild
/ FEL rebuild #1
woolyAcres
Western PA
Antonio Carraro TTR 4400
I'd like to rebuild the FEL on my older Yanmar (24HP) tractor. The frame portion of the loader is pretty decent. There's one weld I've found that needs attention but otherwise things look okay. I know very little about hydraulics, except how to push-pull on the lever when everything is working. Are there places I can buy "a loader rebuild kit" that would include cylinders, hoses, joystick control, etc? Or is this something that needs to be assembled part by part?
The bucket on my machine is far too large for the loader, the bucket 'drops' when left in any position above the ground, and at least one cylinder is 'streaming fluid' so there are significant repairs to do. Did I mention I don't I don't care for the 2-lever control? The loader also isn't removable from the machine because there are no couplers. I don't know much about spooling, float, etc (at least not yet). Is this a diy project for someone with tools and time but limited knowledge?
I'd really like to setup my FEL with a SSQA so I can share loader attachments (bale spear (for 4x4 dry bales) and pallet forks) with my father's larger tractor (NH TC45 with LA16 loader).
For reference Koyker would spec the 120 for my machine . Here's a picture of my machine so you can see what I'm dealing with.
Thanks in advance.
/ FEL rebuild #2
I don't know of any "rebuild kit" for loaders. Usually you have to buy seal kits for the cylinders since the cylinders vary in size from loader to loader. Depending on how bad of shape the cylinder rods are in you may find it less expensive to replace the cylinders Vs rebuilding them again depending on size.
You can purchase replacement joystick type loader valves. Just need to try and match the size (flow rate) with your tractor.
/ FEL rebuild #3
I'd stay with that frame vs a Koyker. Pretty easy to build a QA setup with pins. Obviously, a good stick welder is a must. Size your current cylinders and look at SurplusCenter.com for replacements and a Prince joystick valve. Discount Hydraulic Hose for new hoses. Convert JIC to SAE fittings where possible while you're at it. It is a winter project because you won't be doing it in one weekend for sure! Good luck:)
/ FEL rebuild #4
What is the size of the hoses on your loader? That rear pump might be feeding the loader. Where does all the hoses go to?
/ FEL rebuild
My FEL is currently plumbed into the tractor's normal hydro pump. The same one used for the 3PT hitch. I've actually removed that rear pump (and started a thread about it here).
Some folks far more knowledgeable about this tractor suggest the internal pump (which runs the loader and 3PT) is good for about 4-5 gal at 2200psi. I believe the hoses for the FEL are 3/8", but I'd have to check carefully.
Interestingly, in addition the the rear mounted PTO pump, this machine came with a pump hidden on the front (below the battery) which could, or was, connected directly to a shaft sticking forward from the engine. This pump isn't currently turning. The shaft is not longer connected to the pump, but the pump is there as are the hoses. In fact that reservoir you see on the near (right) side of the tractor is for that front pump. I'd love to reconnect this pump and use that for the loader. The hoses running to and from that reservoir are much larger than the ones running to the FEL so it's possible that pump is more powerful.
/ FEL rebuild #6
The rear hyd pump was sized for the PTO HP. It probably puts out more than the tractor pump.
There should be a model number on the pump to look up the GPM and pressure rating.
So, are you saying you have or had three pumps on your tractor.
/ FEL rebuild
Thanks for the suggestions. However, if this is going to involve a stick welder, there's more to learn than I first thought. ;)
/ FEL rebuild
That rear PTO has already been removed. It was used to power 3 quick connect remote fittings just taped to the loader arms. The lines leading into the loader control valve are 3/8".
/ FEL rebuild
It looks like my two recent posts in this forum are confusing things. I believe it DID have 3 pumps at one time and I'm trying to figure out the volume of this rear pump but that's for the other thread... This PTO pump has been removed. I have no interest in keeping it on this tractor. It ties up the rear-end, so isn't very useful to me.
/ FEL rebuild #10
I guess you could use a Mig. I was talking about for the frame repair and building a frame for a QA. I take it for granted that everyone on this forum can stick weld. Heck without my welder I doubt I'd be able to live out here. Something always needs mending. Tonight I welded two beer cans together with the TIG. How's that for useful?:laughing:
/ FEL rebuild
I'd say that's super useful if they both still have beer in them ;)
There's actually a mig welder in the shed but I haven't used it much. Maybe this is the project to start learning...
/ FEL rebuild #12
LOL! I'd have to change clothes for sure. I only had 2 blow throughs on this one and that is after probably 20 tries less successful. I can only imagine what a 2000 degree arc would do with pressurized Miller Lite. I'll have nightmares about it.:eek:
/ FEL rebuild
Would this be an appropriate controller for my 24HP machine? I'll have to do some plumbing but some of the hoses are shot so I think that's inevitable. This looks to have regen on the dump and float on the other spool. Is there anything else I should be paying attention to when shopping for these?
/ FEL rebuild
I also wonder if such a controller could be mounted horizontally such that the hoses enter from below and the joystick is parallel to the ground and points toward the driver's seat. Do these things have an "orientation"?
/ FEL rebuild #15
You can mount them any way you want as long as you know the orientation.
/ FEL rebuild #16
That's just like mine. Price has gone up, but I really like it. You can set it up for power beyond as well. Mine is mounted very near horizontal. I used a C-clamp to find the most ergonomic angle befoer drilling the mount holes. BTW, the warranty is voided if you paint it so I didn't. Probably will paint it eventually since its been on for nearly four years.
2005 Kubota L39 (A64126)
2005 Kubota L39...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2007 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A59909)
2007 MACK CHN613...
