Farmall Super A hydralic pump smoking
/ Farmall Super A hydralic pump smoking #1
hinghamjd
Hingham, MA
JD 3320, 1947 Farmall Super A
I had to split the tractor to do a freeze plug, so I had to drain the hydro oil. Now that the tractor is back together I filled the hydro reservoir, but the oil is not getting to the pump, is there a way to bleed the lines going to the pump. Thanks
/ Farmall Super A hydralic pump smoking #2
You might need a little air in th ehyd tank to help the flow About 5 lbs of air .
thanks JJ, I'll give that a try
