Farmall Super A hydralic pump smoking
   / Farmall Super A hydralic pump smoking #1
hinghamjd
Hingham, MA
JD 3320, 1947 Farmall Super A
I had to split the tractor to do a freeze plug, so I had to drain the hydro oil. Now that the tractor is back together I filled the hydro reservoir, but the oil is not getting to the pump, is there a way to bleed the lines going to the pump. Thanks
   / Farmall Super A hydralic pump smoking #2
You might need a little air in th ehyd tank to help the flow About 5 lbs of air .
thanks JJ, I'll give that a try
ROADTEC RP-190E-3043 ASPHALT PAVER (A51246)
ROADTEC...
SCAN TO RECEIVE TEXT UPDATES (A51246)
SCAN TO RECEIVE...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
2010 JOHN DEERE 648H SKIDDER (A51246)
2010 JOHN DEERE...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
