John Deere 1020 unknown Carb. Please help
   / John Deere 1020 unknown Carb. Please help #1
chippy126
SC
JD
First Post, I have a 1020 yellow utility model John Deere. I need a new carb. The carb that's on it doesn't have any visible numbers for me to be confident in ordering the correct one to replace it.
I will try to attach some pictures. If anyone can help, it will be greatly appreciated.
carb2.JPG[ATTAcarb3.JPGCH=CONFIG]440056[/ATTACH]
   / John Deere 1020 unknown Carb. Please help #2
You need a Zenith replacement carb for a John Deere 1020 gas tractor.
Anyone that sells replacement carbs ought to be able to run with that info.
If they can't, find another seller.
   / John Deere 1020 unknown Carb. Please help #3
Why do you need a new carb? Most carbs are adjustable and/or repairable.
Found it,, tiny markings on the top. 14966..... The old carb was shoot, the bushings for the main butterfly were worn.. Bad part is ,, I didnt not fix my issue. It still start fine and idle fine, it revs up and after about 30 seconds dies from what appears to be lack of fuel..
Thoughts?
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
2008 Dodge Ram 1500 (A50515)
2008 Dodge Ram...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
IH Cub Lo-Boy 154 (A50514)
IH Cub Lo-Boy 154...
2025 CFG Industrial TK35R Mini Track Loader Skid Steer (A50322)
2025 CFG...
