MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 66,253
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Virginia...
Thanks once again for all the input. Went to Tazewell this morning and met with Chris.
Really great showroom - very organized. Saw one slope mower that automatically adjusts the seat tilt when on steep slopes - nice. Also, saw the PT that is used in mining applications - what a beast. Looks like a monster PT or a military Hummer with a FEL. Mentioned to Chris that the website had been down the last few weeks and he said the problem has been fixed. Website is now working again as of yesterday. Got a CD with video of the different tractors and attachments - well done. Also, had a quick tour of the warehouse with all the inventory - also very organized. I'm satisfied that Power Trac will be around and will stand by their products for many years. Also, like the fact that the price sheets are openly provided unlike other Tractor dealers I have visited. No pressure to buy from Chris.
I was able to demo the PT425 with the 60" mower, 48" tiller, and Mini Hoe. It is great to be able to demo both the attachments and tractor together.
First impressions of the PT - take into consideration that I have never owned or operated a tractor.
It was longer than I thought, more rectangular than square. What a hunk of metal - solid. Looks like the body/frame will last 2-3 life times. Low tech in that there is no LCD panel for the instruments. Simple and sturdy. Not much of a platform for your feet. Steering wheel and seat does not fit the sturdiness of the rest of the tractor. Steering wheel a little upright for me - no adjustment. Quick attach was great. I did notice that the attachments seemed to shake somewhat. Chris said that was the nature of the quick attach. Although the attachment is locked secure it is not real tight so it wiggles.
The 60" mower seems solid but it discharges grass to the rear and I could see the clippings. I have a mulching deck on my zero turn and the clippings are really fine. Not sure the Power Trac deck would be sufficient, would be interested in other comments. Chris said the mower was one attachment that you wanted to have the revs all the way up for proper blade speed so that was not the problem with the clippings.
The tiller performed well. Chris even tilled up a gravel and sand driveway - impressive.
The mini hoe did a great job. Looks like a very good value to me.
Chris confirmed that the larger motor option is no longer available on the PT425 - I had read this in the forum. Asked about heat issues with current motor. He did not think it was a problem. Also, asked about the problems I had read about starting in the cold. He showed me the heat pad in the PT425 demo that he thought worked well. Asked about some sort or clutch to isolate the hydraulics from the motor for easier starting. He said it would add length and cost way too much (around 5 grand if I remember correctly).
I work on my own car and lawn mower so doing my own maintenance with Power Trac assistance fits me. I really dislike playing the "stealer" to fix my equipment. All in all I like the PT425. I like its looks, it's different. I'm currently stuck in SCUT versus PT425 purgatory.
Bill
Well, if you decide to go the Power Trac route, the first thing you'll want to do is get a spinner knob for the steering wheel. It makes all the difference in the world. $10 at Tractor Supply. :thumbsup:
I have the 60" mower on my 2001 model year PT425. It works fine for my lawn and it worked fine for the Little League ball diamonds. It is not, however, the best mower for what I would call a 'show lawn'. If you keep the blades sharp, it gives a nice cut, but it tends to windrow on the right rear of the deck if you let your lawn go long. You can resolve this by mowing in a clockwise fashion from outside the lawn to the center, or counter-clockwise from the center out. But if you are into nice stripe patterns on your perfect lawn, you're going to have to cut more frequently or there will be windrows on every other pass. Also, its a pretty wide single piece deck, so if you have any sharp undulations in your lawn, you may scalp. The front casters are easily adjusted for height with just a pin and spacer rings, but the rear wheels require wrenches. Not a problem if, like me, you never change your cutting height. But if you do, its a 5 minute job with two wrenches.
Funny that you mention it was longer than you thought. I think its just the opposite! :laughing: Find me another 25HP tractor that can lift 800 pounds that can fit in the bed of a standard pickup truck with an attachment attached. Yes, with the front mounted mower, it is long compared to a lawn tractor with a belly mower, or a zero turn unit. But compared to a tractor with front end loader, its a very compact unit.
Yes, the attachments shake on the quick attach. Mine do, to. But 14 years later, none have ever fallen off!
As for cold weather starting, I'm sure he wouldn't think it was a problem. He lives in southern VA.Get that sucker up into a more northern climate and see how it goes. I hope the heat pad works.
And finally, a clutch between the hydraulics and the motor.... yep, it might lengthen the unit. But $5K.... I doubt that. I've seen some electric clutches for small off-road vehicles for about $1k.
Anyhow, welcome to Purgatory... we've all been there at one time. :dance1:
Is there any good leaf solutions for the PT. I believe I read that someone (perhaps you) had tried towing a lawn sweeper while mowing for leaves.
Also, from what I have read there is no ballast required for the PT which would be a big plus for the PT. Attaching front or rear ballast seems expensive as well as a real pain.
Thanks,
Bill
