Help...shoudnt the tires spin ???
   / Help...shoudnt the tires spin ??? #41
There's always an ongoing debate over the pro/cons of hydro vs. gear tractors. If hydro's go into relief, then there's a black mark for them.
I understand why a hydro would have a relief valve, but good god, shouldn't it be rated/set higher than the maximums torques that the engine could produce? (essentially protecting the tranny if someone made post-factory modifications like boosting the fuel pump or adding a bigger turbo etc..) That is, the tranny should be able to handle any torque the engine can dish out and more.
If I buy a 40 hp tractor, I'd expect that all the torque would be able to get to the tires and the tires should either spin or the engine should stall. I WOULDN"T expect the tranny to go into relief at some lesser value! Otherwise I haven't bought a 40 hp tractor.
This is like having a gear tractor and expecting the clutch to slip if the wheels get too much traction and the load is too heavy.
TOTALLY UNACCEPTABLE!
   / Help...shoudnt the tires spin ??? #42
In such a configuration when the drive train can take full power. Now when the hydraulic loaded is operated the engine will bog. Now some operators are going to complain about an under powered tractor . Can't win.
   / Help...shoudnt the tires spin ??? #43
I guess my tractor is set to the minimum pressures for everything because I've never heard any of my relief valves blow off!
   / Help...shoudnt the tires spin ??? #44
Put a hydrostatic tractor in hi range on a three range hydro, and push up against an immovably object and the relief valve will relieve. On a gear tractor put it in your highest gear and push it against an immovable object. What do you think will happen? And if you say the the tires will spin on any kind of hard surface you a most likely telling a whopper. No the most likely thing to have happen is a bunch of clutch facing wear and a bogged down and dying engine.
I think a lot of folks don't realize that the range control is nothing more than a simple gear transmission behind the hydro. Why so many insist on using too high of a gear ratio for the work at hand is a mystery to me.
   / Help...shoudnt the tires spin ??? #45
If I put my tractor in high I better be on a hard level ground, let alone trying to do any work! If I try to take anything more then a little scoop of the manure pile in med rang I can't do it! Low range is the only suitable "working" range for my 4041h! I have never hear my relief valve go off and I have stalled my tractor working in medium range a few times while in the process of learning that less pedal means more grunt!
   / Help...shoudnt the tires spin ??? #46
Ok won't talk about "ramming"
XR4046H No problem in M range moving with loads of brush and even pushing the piles up. Even been able to push some small trees up with roots. Have also stalled the engine doing this a few times but not much "tire spinning" in M range. No problem spinning tires in L range. Have not found much use the H range except for a small amount of road travel and our road is very flat.
   / Help...shoudnt the tires spin ??? #47
(IMHO): The "weak link" on a working tractor should be either motor horsepower (torque) or traction. Not a transmission relief valve (or slipping clutch) that doesn't allow all of the engine power to get to the wheels. Stall or spin!
   / Help...shoudnt the tires spin ??? #48
My R4047H will spin 3 tires on pavement in low gear. It'll go into relief in mid range. I can't complain with that. Theres a lot of variables to each situation as fat as ballasted weight and tire pressures and the surface you're on. I feel like mine puts down a good amount of its potential power to the ground before relief.
   / Help...shoudnt the tires spin ??? #49
I feel like the 4047 is a more appropriate hp for that frame then the 4041 at least in the hydro. The thing I don't get I its all the same hydraulics so why does the 47 seem so much more responsive?
   / Help...shoudnt the tires spin ??? #50
I use high range now than I ever did. Drop it in 4 wheel mid to scoop and pop it in high 2 wheel to transfer.1800 rpm
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2014 MERCEDES 2500 CARGO VAN (A59904)
2014 MERCEDES 2500...
Deere 310L (A53317)
Deere 310L (A53317)
17307 (A55853)
17307 (A55853)
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
