Kubota B2320 wont start unless jumped
   / Kubota B2320 wont start unless jumped #1
207seanb
waterboro, me
kubota b2320
Please help my Kubota only starts when I jump it but if I use anything electrical after jumping it, it stalls and wont start again unless jumped. The battery says it has a full charge & I tested it. I also cleaned the battery cables. I know it is something simple because the previous owner took very good care of this Kubota.
   / Kubota B2320 wont start unless jumped #2
Chances are you need a new battery. When a motor starts OK with a jump, then dies when the donor is disconnected, it is almost always because the impaired battery is deceased.
When it is time for a new battery, it is time, especially with cold weather coming soon in Maine.
In my experience you need a minimum voltage reading of 12.4 volts on a charged battery. 12.3 volts will not serve.
I always replace with Interstate (brand) batteries. A bit more money up front but Interstate batteries last for years.
   / Kubota B2320 wont start unless jumped #3
Did you test the battery with a load tester....like they do at Walmart, Autozone, etc.? if you haven't already, clean the end of the ground cable where it attaches to the tractor.
   / Kubota B2320 wont start unless jumped #4
At this stage of the diagnosis,the charging voltage of the alternator/dynamo must be checked!
Low voltage may cause the shutdown problem.
Please measure your running voltage and post back.
Good Luck!
   / Kubota B2320 wont start unless jumped #5
Forgot to mention charging voltage should be about 14 volts DC
A fully charged 12V battery will test 12.6 volts-2.1 volts per cell.
I appreciate everyone's help in this matter & I will post the outcome as soon as I discover it, listening to everyone's advice I am new at all this :) Thank You
IT WAS CLEARLY THE BATTERY, The load test was very weak!!!! THANK YOU ALL
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58214)
(INOPERABLE)...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
159114 (A60429)
159114 (A60429)
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2017 Mahindra Emax 22 Tractor (A59814)
2017 Mahindra Emax...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
