Kubota B2320 wont start unless jumped
   / Kubota B2320 wont start unless jumped #1
207seanb
waterboro, me
kubota b2320
Please help my Kubota only starts when I jump it but if I use anything electrical after jumping it, it stalls and wont start again unless jumped. The battery says it has a full charge & I tested it. I also cleaned the battery cables. I know it is something simple because the previous owner took very good care of this Kubota.
   / Kubota B2320 wont start unless jumped #2
Chances are you need a new battery. When a motor starts OK with a jump, then dies when the donor is disconnected, it is almost always because the impaired battery is deceased.
When it is time for a new battery, it is time, especially with cold weather coming soon in Maine.
In my experience you need a minimum voltage reading of 12.4 volts on a charged battery. 12.3 volts will not serve.
I always replace with Interstate (brand) batteries. A bit more money up front but Interstate batteries last for years.
   / Kubota B2320 wont start unless jumped #3
Did you test the battery with a load tester....like they do at Walmart, Autozone, etc.? if you haven't already, clean the end of the ground cable where it attaches to the tractor.
   / Kubota B2320 wont start unless jumped #4
At this stage of the diagnosis,the charging voltage of the alternator/dynamo must be checked!
Low voltage may cause the shutdown problem.
Please measure your running voltage and post back.
Good Luck!
   / Kubota B2320 wont start unless jumped #5
Forgot to mention charging voltage should be about 14 volts DC
A fully charged 12V battery will test 12.6 volts-2.1 volts per cell.
I appreciate everyone's help in this matter & I will post the outcome as soon as I discover it, listening to everyone's advice I am new at all this :) Thank You
IT WAS CLEARLY THE BATTERY, The load test was very weak!!!! THANK YOU ALL
Metal Platform Cart (A49251)
Metal Platform...
2024 Kubota RTV-X1100C Utility Cart (A46684)
2024 Kubota...
RTB Half Bar Hay Saver (A49251)
RTB Half Bar Hay...
CAT 262B Skidloader NON-RUNNING (A49251)
CAT 262B...
Side Dresser (A49251)
More info coming soon! (A48081)
More info coming...
