JD 997 Zero Turn-No Start
/ JD 997 Zero Turn-No Start #1
9973720wb19
East Coast
Many
I have a 997 Diesel Zero Turn with about 250 hours. I don't use it much; went to start it today and got a clicking noise when turned the key. I keep the battery on a charger and it's showing "Green" as in fully charged. What' the issue here?
/ JD 997 Zero Turn-No Start #2
Clean and check all the battery connections and grounds. Have the battery load tested.
/ JD 997 Zero Turn-No Start #3
Safety switches/interlocks?
Dirty/corroded battery cables/terminals?
/ JD 997 Zero Turn-No Start #4
I'd also suspect bad connections first, but wouldn't rule out a bad battery either. May be plain "wore out".
/ JD 997 Zero Turn-No Start #5
Strongbox batteries are notorious for sudden failure. The battery on my X748 was about 6 years old when it failed, but it worked perfectly, then one day I was mowing, shut it off to take a break, then it wouldn't crank the engine. Would only put out around 10 volts when it was presented with any kind of load.
Many thanks all! After reading this and chatting with the Dealer, I'm going to replace the battery first. Apparently, it can show "full charge" on a charger, but not have the cranking amps. Btw, that's what happened. it ran fine and now nothing but a few clicks and wines...
IT WAS THE BATTERY! Installed a new one and it fired right up. Good thing because the Dealer said they would not come out and look at it - I had to bring it in. Pretty hard to do when lives at end of a hilly long trail at my shop.
/ JD 997 Zero Turn-No Start #8
Glad to hear it. How old was the battery?
/ JD 997 Zero Turn-No Start #9
I saw 2 DOA Strongbox batteries this year that were supposed to be "Dealer Charged" prior to sale. Im gathering that sudden death with these batts is pretty common. Not impressed with them at all.
I purchased the 997 in June 2008 - it was the original battery...so it's 6 years old or so. I'm good about keeping batteries on a trickle charge - I guess a cell or two got damaged/failed.
/ JD 997 Zero Turn-No Start #11
That is about right for a battery IMO.
I get that, and don't ever trickle charge.
/ JD 997 Zero Turn-No Start #12
I just replaced a 3 year old battery on my 2720. I stopped to clean the chaff off the grill in a shady spot and the battery didn't have enough juice to run the wipers. I think all the bouncing the battery does in front end when mowing a little fast is the culprit.
I saw an "Eric the Car Guy" (Battery Maintenance - title I think) on You-tube showing how dirt on top of the battery can become conductive and cause a drain. And we all know how much grass, mud and dirt gets on our equipment.
2022 John Deere 520M Loader (A63116)
2022 John Deere...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2021 Salford 550-30 Cultivator (A63116)
2021 Salford...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2005 John Deere 310SG Backhoe (A64047)
2005 John Deere...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
