3-Point Hitch Case 1394 3 point not working
/ Case 1394 3 point not working #1
BCmetalman
Prince George B.C.
Kubota M9000
Hello all, I'm a new member here, hoping someone can offer some suggestions;
I just bought a Case 1394 (mid 80's, diesel, 65 pto h.p.) She's a little rough cosmetically, but runs good, and the loader works well, with plenty of lifting power. I have a manual on the way via ebay, but meanwhile.........
My problem is the 3 point hitch lower arms will not go up. They are in the 'down' position, and I can lift them up by hand, but
when I pull back on either of the control levers, the engine bogs slightly but nothing else happens.
Any ideas?
Thanks.
/ Case 1394 3 point not working #2
Check if the linkage from 3 point lever is connected to the valve. Also if for some reason your 3 point hydraulic is plumbed after loader or remote outlets the loader and remote control valve has to be in neutral position for 3 point to work. Normally 3 point is plumbed first and remotes and loader from power beyond so this is just a unlikely possibility.
Hi R.i.t. thanks for replying.
Your suggestions give me a starting point, so I will look at those first.
Will report back.
Regards,
Toby
/ Case 1394 3 point not working #4
My 1494 has a small push/pull rod left side of the seat that diverts hydraulic fluid or isolates it to the loader. Sometimes it gets knocked into the wrong position and I think there is a problem until I recycle that rod.
Thanks for the idea, I will check that too.
Hoping to have a look at the tractor tomorrow if time permits, will advise.
BCmetalman
46184SFL (A64557)
46184SFL (A64557)
2002 Ditch Witch 1230H Walk-Behind Trencher (A64553)
2002 Ditch Witch...
2017 Ford Escape SUV (A64557)
2017 Ford Escape...
2006 INTERNATIONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2016 PETERBILT 337 CAB AND CHASSIS (A65643)
2016 PETERBILT 337...
