3-Point Hitch Case 1394 3 point not working
/ Case 1394 3 point not working #1
BCmetalman
Prince George B.C.
Kubota M9000
Hello all, I'm a new member here, hoping someone can offer some suggestions;
I just bought a Case 1394 (mid 80's, diesel, 65 pto h.p.) She's a little rough cosmetically, but runs good, and the loader works well, with plenty of lifting power. I have a manual on the way via ebay, but meanwhile.........
My problem is the 3 point hitch lower arms will not go up. They are in the 'down' position, and I can lift them up by hand, but
when I pull back on either of the control levers, the engine bogs slightly but nothing else happens.
Any ideas?
Thanks.
/ Case 1394 3 point not working #2
Check if the linkage from 3 point lever is connected to the valve. Also if for some reason your 3 point hydraulic is plumbed after loader or remote outlets the loader and remote control valve has to be in neutral position for 3 point to work. Normally 3 point is plumbed first and remotes and loader from power beyond so this is just a unlikely possibility.
Hi R.i.t. thanks for replying.
Your suggestions give me a starting point, so I will look at those first.
Will report back.
Regards,
Toby
/ Case 1394 3 point not working #4
My 1494 has a small push/pull rod left side of the seat that diverts hydraulic fluid or isolates it to the loader. Sometimes it gets knocked into the wrong position and I think there is a problem until I recycle that rod.
Thanks for the idea, I will check that too.
Hoping to have a look at the tractor tomorrow if time permits, will advise.
BCmetalman
2020 BOBCAT T770 SKID STEER (A65053)
2020 BOBCAT T770...
1997 Volvo WG Day Cab Truck Tractor (A64194)
1997 Volvo WG Day...
2016 TAKEUCHI TB240 EXCAVATOR (A65053)
2016 TAKEUCHI...
2022 EZ-GO ELITE...
More info coming soon. (A64557)
More info coming...
ROME RLS12 HYD SCRAPER (A63276)
ROME RLS12 HYD...
