3-Point Hitch Case 1394 3 point not working
/ Case 1394 3 point not working #1
BCmetalman
Prince George B.C.
Kubota M9000
Hello all, I'm a new member here, hoping someone can offer some suggestions;
I just bought a Case 1394 (mid 80's, diesel, 65 pto h.p.) She's a little rough cosmetically, but runs good, and the loader works well, with plenty of lifting power. I have a manual on the way via ebay, but meanwhile.........
My problem is the 3 point hitch lower arms will not go up. They are in the 'down' position, and I can lift them up by hand, but
when I pull back on either of the control levers, the engine bogs slightly but nothing else happens.
Any ideas?
Thanks.
/ Case 1394 3 point not working #2
Check if the linkage from 3 point lever is connected to the valve. Also if for some reason your 3 point hydraulic is plumbed after loader or remote outlets the loader and remote control valve has to be in neutral position for 3 point to work. Normally 3 point is plumbed first and remotes and loader from power beyond so this is just a unlikely possibility.
Hi R.i.t. thanks for replying.
Your suggestions give me a starting point, so I will look at those first.
Will report back.
Regards,
Toby
/ Case 1394 3 point not working #4
My 1494 has a small push/pull rod left side of the seat that diverts hydraulic fluid or isolates it to the loader. Sometimes it gets knocked into the wrong position and I think there is a problem until I recycle that rod.
Thanks for the idea, I will check that too.
Hoping to have a look at the tractor tomorrow if time permits, will advise.
BCmetalman
2007 Toro Z-Master 72in. Zero Turn Commercial Mower (A64553)
2007 Toro Z-Master...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
2008 21 Ft. Sea-Doo Speedster Boat with 2008 22Ft. Karavan S/A Trailer. (A64557)
2008 21 Ft...
2017 Ford Transit 250 Cargo Van (A64556)
2017 Ford Transit...
Peacock (A64557)
Peacock (A64557)
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
