G8965M
Looking to buy a jd 301 A that has a good engine but when you let out on clutch engine dies due to something locked up in the rear end or power drive. Anybody seen this problem or can help?
I'm wondering if maybe the Main hyd pump may be locked up causing the problem? Feed back is appreciated!
With the tractor jacked up the wheels turn freely and I can shift freely through all the gears. That is why I was asking about the drive unit pump. If the gears was stuck will I be able to shift through gears and spin wheels freely?
