Backhoe rails tied into FEL cross member
I haven't posted a crude drawing of my hybird mount idea yet but basically the backhoe frame rails from the FEL cross member to the rear will look similar to the LS factory mount that is unobtainium but with a twist ... the portion under the tractor will be permanently mounted and support the 4 point backhoe mount on the rear of the tractor.
I cut a notch out of the 2x4 tube to mate with the FEL cross member that runs under the tractor between the FEL mounts. The forces from the backhoe will push up on this member and try to lift the front of the tractor spreading out the force.
Here's a picture while closing the ends with some 3/16". I used my small MIG with flux core for this since it wasn't structural ... everything else is 6011 & 7018 stick:
I welded 1/2" plate to the FEL cross member so I can fasten the rails to the FEL cross member with bolts. These 'ears' stick down about the same distance under the tractor as the FEL loader mount that connects to the ROPS/transaxle housing in the rear:
The backhoe rails in the front also have 'ears' to mate with the FEL cross member:
View of the modified FEL cross member sitting on the rails. In the side view you can see the two plates against one another. I had fun drilling bolt holes in that tonight:
Now I'm figuring out how I want to go about mounting the rails at the rear of the tractor ...
This is my first project with my plasma cutter so don't laugh too hard at my rough parts ... I've still trying to get my technique down. It's not the machine ... It's all me. When I was cutting 1/2" plate I kept tripping breakers and quickly learned 20Amps wasn't enough so I had to modify my extension cord to use the 30Amp dryer plug (which makes the wife real happy).
