Any news on gas engine CUTS?
Status
Not open for further replies.
/ Any news on gas engine CUTS? #541
I guess my point is that while these small tractors can do a ton of work and are occasionally worked very hard, let's not over estimate their duty cycle design.
Absolutely. That's why I've pointed out that making comparisons between a SCUT/CUT and a 200hp Ag machine is pretty silly. It's certain that they're built heavier, and sturdier per rated horsepower than anything you'd find in a SCUT/CUT.
With that said, I suspect that the average 40hp CUT should be capable of doing serious work, mostly at PTO speed, and last multiple thousands of hours without major problems.
/ Any news on gas engine CUTS? #542
Another useless empty argument from you. Gee... are gas engines under the tier 4 diesel engine scope?
No the gassers are not tier IV diesel spec which is the advantage . It's a lot simpler to make a spark ignition engine burn clean with the lighter fuels they use.
In light and medium duty puttering around applications the spark ignition is simpler and cheaper to run clean. The diesel needs to be operated at full rpm and full load for only extended duty cycles . To be fuel efficient and to have clean stack emissions .
/ Any news on gas engine CUTS? #544
Sounds fine. But that was only for 1/2 hour. Scut and cut tractors need to run for hour after hour after hour.
Just as importantly . . your radiator didn't overheat but what was youe engine temperature? Wide open . . . Wow . . . Good way to cook your oil or tranny fluid.
Who uses a CUT or SCUT at max rated rpm and at full rated power for hours at a time. If you do , you purchased a hobby tractor that is two or three sizes too small. The typical small tractor is a 50 to 100hr a year machine performing puttering around jobs. If somebody has set out with a 2x14 plough into a 100 acre field . The operator is overly optimistic .
/ Any news on gas engine CUTS? #545
I dont know about that. My BX1500 works for a pretty significant part of its time at full load.
With HST its easy to hold absolute full load at the bog point in mowing, snow throwing, climbing hills, etc. It also runs about 90% running our pto gen during a power outage. It has 2100hrs and uses right at a gallon an hr at full load.
/ Any news on gas engine CUTS? #546
I never said a fork truck was a light duty cycle. I said it wasn't as heavy duty a cycle as a tractor.
Further, fork trucks don't have anything that puts shock to the engine the way PTO implements can, so they have to be built to withstand that.
If a fork truck engine could survive in a tractor they would have switched tractors over to using engines that small and light (for their power output) years ago.
Not while there was tier I, II and III emissions and fuel was cheaper high sulphur. Now in the midst of Tier IV with tier V on the horizon. An engine that burns lighter fuel will have to be considered.
Why not yet? Research takes time and money. Manufactures took a wait and see position if Tier IV would be repealed . Manufactures also have a huge market outside of the U.S. with little to no emissions and diesel fuel cheaper than gasoline . Of course the manufacture will build for the low end market and stick rich US customers with the cost of emissions equipment.
/ Any news on gas engine CUTS? #547
Read the Kubota web site about spark ignition engines to be used where a Tier IV diesel is not practical. Says industrial and construction applications. Those engines are build for high demand over extended periods of time. Is Kubota going to design and build engines when there is no market for them? Who was the poster anyways with the inside track that said preliminary engineering had been terminated on spark ignition industrial engines ?Kubota Engine America - LATEST NEWS
/ Any news on gas engine CUTS? #549
Because I want to. That's why. :rolleyes:
Do you own a time machine for trips back to 1993?
The topic is about small light and medium equipment in 2015 and later . That may have to consider spark ignition engines to achieve clean stack emissions at reasonable upfront purchase and service costs. Btw Kubota and that concrete equipment manufacture Whiteman are in the market right. Is with spark ignition engines .The Impact of Tier 4 Diesel Engines - Concrete Construction
/ Any news on gas engine CUTS? #550
The topic is about small light and medium equipment in 2015 and later . That may have to consider spark ignition engines to achieve clean stack emissions at reasonable upfront purchase and service costs. Btw Kubota and that concrete equipment manufacture are in the market right. Is with spark ignition engines .
I wasn't conversing with you. I was conversing with someone about the mileage on their Jetta. Conversations are fluid and change. If you don't want to converse with someone on an open forum, stop responding to them. As for a time machine....
/ Any news on gas engine CUTS? #551
Anyone who is cutting 12 to 20 inch grass.
Anyone who is tilling community gardens
Anyone who is snowblowing in WI, MN, or MI snowfalls on wind driven ridges .
Anyone who thinks $15,000 to $35,000 is real money.
/ Any news on gas engine CUTS? #552
Typical hrs/yr do not equate to typical proportion of full load used when its running. HST is easy to run at full load if you have a motion based load.
/ Any news on gas engine CUTS? #553
Exhaust valves too and maybe rings.
/ Any news on gas engine CUTS? #554
Or lush 5-8" tall irrigated grass. I have mowed both "hayfield" grass/weeds that is 12-36" tall and 5-8" tall irrigated grass and the shorter thicker grass put a lot more load on the engine.
I would hazard a guess that most commercial zero turns spend a much greater percent of their running time at or near rated power than most CUTs and SCUTs during mowing season.
Yes, mowing tall grass will make a CUT or SCUT work, but our BX2660 (with the 60" deck) cannot go fast enough to bog down and get to 100% load unless its an area that hasn't been mowed for 3-4 weeks.
Aaron Z
/ Any news on gas engine CUTS? #555
Aaron Z
Obviously your experience is with sparse grass. I cut 5 to 8 inch bluegrass all the time and it is thick and lush and that cettainly doesn't challenge my engine like the tall wetlands grasses do. There is no way my zero turn could cut that area without frequent cool down breaks and a need for triple cutting.
/ Any news on gas engine CUTS? #556
What ZTR do you have? My ZTR experience is mostly with 2005ish 25-27HP (Kawasaki) air or water cooled Exmark Lazer Z mowers with 60" and 72" decks on them mowing a mox of fields, non-irrigated "normal" grass and irrigated lush thick grass. We were not allowed to have any appreciable amount of visible clippings, so the lush grass got double or triple cut in the spring/early summer.
As long as we kept the radiators/cooling fins blown out they never even thought about overheating (no matter how hard the guys pushed them). Bog down, yes. Stall out, yes. Burn up the "mule belt" that went from the engine to the desk jackshaft, yes (on occasion). Kill the engine when the nylon gear driving the oil pump stripped, but not overheat.
Aaron Z
/ Any news on gas engine CUTS? #557
Aaron Z
I'm with you.. I have a z turn 22 hp Kawasaki .. I cut about 5 acres of grass..
Run the engine wide open for hrs..Wide open is the way they are designed to run..
Never burn up the oil or run hot.. Mine is an air cooled engine
I have heard of this super duper tough grass ,that some have.. I understand no gasoline engine can stand the stress of cutting it:rolleyes:
/ Any news on gas engine CUTS? #558
One of the gaping holes that "gas engines for scuts and cuts" keeping talking about without reference . . Is what is needed in a gas engine to mimic the performance of diesel in a scut or cut tractor.
It will require high compression gas engines with clean burn characteristics. A high compression engine is typically defined as an above 9.1 compression ratio. 9.1 and below allows use of regular gas (preferably none ethanol). To attain both cleaner burning and higher compression ratio performance a non-ethanol octane of 90 or above is desired with even higher octane levels for cpmpression ratios above 12.
Failure to use a higher octane in a high compression engine will cause 2 things:
1. Decreased actual burning of the gas fuel = lower mileage/hours per gallon.
2. Increased unburned hydrocarbons and emission issues.
That means premium gas and premium gas pricing . . Current price in our area is $3.29.
My massey gc1715 duesel operates at a 22.5 compression ratio and I use premium diesel (including road tax) of $ 2.59 per gallon.
Now isn't it strange that gas proponents don't seem to mention this that the fuel costs of a yet to be developed gas scut/cut tractor engine would actually be considerably higher than diesel . . . not lower :)
Your way off on your calculations! There wont be a need for premium fuel and there wont be a need for a compression ratio at 12 to 1. You are not taking into account dynamic compression and the duration and overlap of the cam you will need to get the power rating needed for a tractor use.
/ Any news on gas engine CUTS? #559
My 11:5 compression ratio motorcycle runs on 87, and was designed to use it. Looks like there's more involved in engine designing than you understand.
There is more involved than most here will ever understand! I also have a few engines with compression ratios higher than 11;5 that run on 87.
/ Any news on gas engine CUTS? #560
No one has mentioned compression ratios. If you tried to put 23/1 compression on a gasoline engine, it would be disasterous.
Eugene
Direct injection solves much of this- can't have preignition if the fuel isn't injected until after the point of pistons relationship to tdc that preignition can occur.
Or there might also be a change in the size and strength of the parts -starting with pistons/ rods
:D my 554 diesel tractors piston/rod vs. my boats Volvo OHC gas piston/rod compare this way...
Both will run at rated power for a very long time- one at @ 5000rpm @ 9:1 130 hp 130 cu inch
the other @ 2000rpm @16:1 and (only) 55 hp 203 cu inch guess which one is the 55 hp diesel :laughing:
I like the HD low rpm diesel design for tractor work. the gas version works well for a boat engine that needs a much wider RPM operating range
I would think that a gas engine would actually work pretty well for a hydrostatic drive tractor- ( pin the throttle) and go
but if a gear drive- give me a low rpm/large cu inch diesel all the way
Status
2011 FREIGHTLINER M2 112 CNG (A59909)
2011 FREIGHTLINER...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
8087 (A61165)
8087 (A61165)
UNUSED LANDHERO LDH-LB9510 LEAF BLOWER (A62131)
UNUSED LANDHERO...
New/Unused Hydraulic Thumb for CFG Mini Skid Steer (A61166)
New/Unused...
1994 CUSTOM FAB 94" X 14' GOOSENECK HORSE TRAILER (A62130)
1994 CUSTOM FAB...
