John Deere 820 wont run.
/ John Deere 820 wont run. #21
I tried hooking up a battery charger to the tractor to see if it was a voltage problem but it still does the same thing. Im not sure how the shut off works on these tractors there is no selonoid on the out side of the pump like on a piston pump this tractor has a rotary pump. The lift pump is leaking is leaking but it is pumping could this be the problem that it is not pumping enough fuel?
If the low pressure mechanical pump is broken, it's broken . Replace it.
/ John Deere 820 wont run. #22
Won't run? Won't crank? Cranks and Won't start ? When did it last run? Did you bleed the fuel system from tank to injection pump? Is there clear unimpeded full flow from tank to injection pump?
Is there a mechanical pull knob or electric shut off ?
Replaced the lift pump but still have the same problem. It will run about five minutes now and die. It also is smoking pretty bad now. I bled all the lines and made sure they are clear of debris and flowing well. So does that mean that the injection pump needs rebuilt?
/ John Deere 820 wont run. #25
maybe......................New injectors installed after the pop pressure is verified are recommended. Even if the injectors are not fully at fault they will be worn out .
Valve lash?
Has some ding dong beat the engine to bits by spraying ether instead of plugging in the block heater for winter starting ?
something somewhere plugged in the intake system?
Is there excess crankcase ventilation blowby?
Thinned out crankcase oil diluted with diesel will walk right past the rings and make her smog.
/ John Deere 820 wont run. #26
Did you check fuel return line that attaches to inj pump for blockage??
Yes i have checked all lines for blockage took them off and blew compressed air through them but nothing was in them. So that about leaves injection pump and injectors right?
/ John Deere 820 wont run. #28
If you're 100% positive that the check valve fitting(parts key 5) isn't plugged then yes inj pump repair is required. As one last attempt to get engine to run before removing IP loosen screws on timing window(parts key 9) and attempt to start engine. Be sure gasket isn't stuck to pump housing. Yes you'll loose a little diesel but IF engine runs a small amount of lost diesel will be nothing compared to $$$$ of pump repair bill.
how do i tell if the check valve is unplugged? I took it off and it does have a lot of stuff in it so i blew it out with compressed air but how do check that it did the trick?
/ John Deere 820 wont run. #30
Some tractor owners/technician have removed glass ball & spring. If you loosen timing cover & gasket and engine runs then you'll know check valve MUST BE PLUGGED. Plugging of check valve indicates fiber drive ring is deteriorated in IP and needs to be replaced to avoid costly inj pump failure or worse scenario connecting rod protruding through side of engine block.
I tried the pulling the timing cover and the tractor did run so i cleaned the check valve again and the tractor is now running for at least 15 mins. So do i still need to have the pump rebuilt because it was some type of material that the valve was plugged with possibly the fiber drive pieces maybe?
/ John Deere 820 wont run. #32
I've seen those IP run for several yrs with deteriorating drive rings but you're just postponing the trouble & expense. With repair prices escalating every yr I think you'ld be money ahead to get it repaired now.
/ John Deere 820 wont run. #33
banditman
Did you get this problem fixed? If so, what was the solution? tks
banditman
Yes it was a piece of material stuck in the check valve on the top of the fuel pump ended up having to eliminate the check valve because i couldnt find a new one so it doesnt start as easy as it ounce did but at least it will run now
/ John Deere 820 wont run. #35
820 IP check valve is JD part # R36535 CONNECTOR,WITH CHECK VALVE ADD 29.72 US. Or you could probably get it from IP parts supplier.
/ John Deere 820 wont run. #37
Though years later, thought a note might add value to someone. Had the same issue with an 820 diesel (German/French). Ran OK (always had a little skip at high rpm; figured it was injectors so didn’t much worry about it) before a filter change then would only run a min or two. Swapped filters, checked fuel from tank, checked pressure from the ‘lift pump’, checked flow through filters, checked check valve on top of roosa inj pump. No luck. Gave in and had the roosa pump rebuilt and installed new injectors. Done! Runs like a top. Was not a cheap date at ~ $2500. Timing was odd but hey, never know.
